23140
56
Регистрация: 13.04.2018 Последняя активность: 07.10.2019 14:30
Weekly special deal: Ends on 23:59PM, 18Th, May
1.VOOPOO MAAT Tank ![]() Original price:39.9 Discount price:27.93(Coupon Code:MAAT) 2.Joyetech Exceed Grip Kit ![]() Original price:$26.7 Discount price:22.7(Coupon Code:EXCEED) Buy electronic cigarette online at buybest, fast delivery and free shipping worldwide over $20! |
180W IJOY Shogun Univ TC Kit with Katana Tank $54.56
Shogun Univ MOD and Katana Tank from Ijoy consist the stylish IJOY Shogun Univ kit. Katana Tank together with the Shogun Univ MOD, the IJOY Shogun Univ Kit will be the best e-cig kit you ever use. ![]() 126W IJOY Shogun JR Resin TC Kit with Shogun Tank $54.27 The IJOY Shogun JR Resin MOD and the Shogun Tank consist the 126W IJOY Shogun JR Resin TC Kit. BuyBest has Rainbow, Stainless Steel, Red Tan color on sale now. ![]() MOUU Cliq Pod System Kit $23.57 MOUU Cliq Pod System Kit comes with 420mAh built-in battery and a 1.4ohm ceramic coil to produce an optimal flavor for you. In addition to the leakage and dustproof design, it will bring a lot of conveniences for you to go and vape anywhere and anytime. ![]() THC Tauren Max Mech MOD $139 THC Tauren Max Mech MOD, with an attractive appearance, adopts high compatibility with a single 18650/21700/20700 battery. And the full contact and low voltage drop also guarantee you a strong power for your vaping. ![]() 80W Eleaf iStick Rim Kit with MELO 5 Atomizer $60.97 Eleaf iStick Rim Kit comes with 3000mAh built-in battery, various in Wattage, and a large LED screen to show you the status of the Battery. It adopts the bran-new EC S/M coils to produce huge clouds and intense flavor. ![]() Best electronic cigarettes at buybest, free shipping, and fast delivery! |
Hey guys, the May Super Sale is coming! High to $10 OFF 100
![]() Sale Time: 14th-22nd May, 2019(PST) 1.$2 OFF $30 with Code MAY2 2.$5 OFF $50 with Code MAY5 3.$10 OFF $100 with Code MAY10 Find more great deals: http://www.buybest.com vaporesso swag mod:https://www.buybest.com/Vap... |
Here comes Vaporesso VM 18/22/25 Sub Ohm Tank, a new series of Vaporesso family. The VM 18/22 Tank is featured with 2ml e-juice capacity, while the VM 25 Tank holds the storage of 3ml. The Vaporesso VM 18/22/25 Sub Ohm Tank adopts two coils—CCELL coil for Nic salts/CBD and tea fiber meshed coil for free base e-juice. The top refilling system and bottom AFC of VM Tank helps you acquire pure and dense flavor with thick clouds. Come and buy one Vaporesso VM 18/22/25 Sub Ohm Tank for you vaping.
![]() Vaporesso VM 18/22/25 Sub Ohm Tank VM 18 Tank Product Size : ⌀18mm x 49mm Refillable Tank Capacity: 2ml Coil: 1.0 Ω EUC CCELL Coil (10-14W); 0.6 Ω EUC MESHED Coil (16-22W) Thread: 510 VM 22 Tank Product Size : ⌀22mm x 49mm Refillable Tank Capacity: 2ml Coil: 1.0 Ω EUC CCELL Coil (10-14W); 0.6 Ω EUC MESHED Coil (16-22W) Thread: 510 VM 25 Tank Product Size : ⌀25mm x 51mm Refillable Tank Capacity: 3ml Coil: 1.0 Ω EUC CCELL Coil (10-14W); 0.6 Ω EUC MESHED Coil (16-22W) Thread: 510 The Vaporesso VM STICK 18 Starter Kit is worthy of your purchase. The VM STICK 18 comes with a ergonomically small shape for you to carry easily. Featured by an OMNI board chipset, the kit comes with a 1A quick charge and a 1200mAh battery to support your whole day vaping. What is more important is that two coils are available for you—CCELL coil and MESHED coil—to meet your different demand of vaping and bring you a wonderful sense of smoke. Come and buy one Vaporesso VM STICK 18 Starter Kit for you vaping. ![]() Product Size: 18 x 124mm Refillable Tank Capacity: 2ml Coil: 1.0ohm EUC CCELL Coil (10-14W); 0.6ohm EUC MESHED Coil (16-22W) Built-in Battery: 1200mAh Charging Current: 1A Thread: 510 Here comes the POMP Tetris Pod System Kit with longer and ergonomic drip tips for CBD vaping. It adopts the unique VPOCERA™ Zisha ceramic coil, which, with customized heating wire and increased heating area, is designed for CBD oil. Customized features such as preheating and 3 optional output (Powerful/Normal/Soft) Modes are equipped. Powered by 400mAh built-in battery, POMP Tetris Pod System Kit can serve your whole day vaping. The easy top filling system and L-type oil-air separation structure design will optimize the taste and prevent the leakage problem for you. Moreover, POMP Tetris Pod System Kit is protected by the 5-in-1 safety system, which guarantees a safe vaping environment for you. ![]() Size: 69 x 38.8 x 8mm Battery: 400mAh built-in battery Pod Capacity: 0.5ml Coil Resistance: 1.5ohm Charging Voltage: 5V Charging Current: 500mA Output: 3-17.5W Preheating time: 10s Output Mode Voltage: 2.7V / 3.7V / 4.2V Support: CBD Vape Oil (PGVG/MCT) / Full Spectrum CBD / Nicotine salts e-Juice The AI EVO Pod System Kit comes with fashionable and eye-catching pattern. Powered by 1100mAh built-in battery and engineered to enable max 20W output, the AI EVO is aiming to provide you a best flavor. The AI EVO Pod Cartridge comes with 2.8ml e-juice capacity, and is the perfect choice for both DTL and MTL vaping. Moreover, the innovative bottom-press refilling system is highly recommended. The AI EVO can automatically detect the atomizer's resistance. Two coils are available for you—the pre-installed 0.7ohm mesh MTL coil, made for intensive clouds chasers, and the additional 1.4ohm coil, optimized for nic-salts. Come and buy one AI EVO Pod System Kit and start to enjoy your vaping. ![]() IJOY AI EVO Pod System Kit Size: 94 x 30 x 18 mm Battery: 1100mAh Built-in battery Max Power: 20W Output Voltage: 3.3V-4.2V Material: Zinc Alloy & stainless steel & resin Coil: 0.7ohm mesh MTL coil (preinstalled)/ 1.4ohm coil(not installed) Capacity: 2.8ml Fill Type: Bottom-pressing refilling Kinds of the latest vape products at buybest, take time to get your first electronic cigarettes now! Get more new arrival at: New Aaaival More Sales: Vape Flash Sale, Clearance, Sale Items |
Here comes the new round of our Vape flash sale. Product list as below. Ends at 16:00 PM on May.29(PST).
![]() 320W SMOK G320 Marshal TC Box MOD(Only Sliver) 228W Joyetech eVic Primo 2.0 Kit with UNIMAX 2 Atomizer(Only Bronze) 75W Ehpro 101 Pro TC Kit with Lock RDA(Only Rainbow) Giraffe Microphone Speaker for Kids(Only Yellow) GeekVape Athena Mechanical Squonk MOD(Only Sliver) WOTOFO Lush Plus RDA(Only SS) Smoant Karat Pod Starter Kit(Only Bronze Blue) Thank you & enjoy shopping at www.buybest.com cheap vape starter kit and cheap vape accessories at BuyBest. |
Hey guys, the World No Tobacco Day Sale is coming! High to 80% OFF.
![]() Sale Time: 25th.May-5th.June, 2019(PST) 1.Super Flash Sale 2.Coupon Deals 3.Best Seller Find more great deals: https://www.buybest.com/eve... vaporesso swag mod:https://www.buybest.com/Vap... |
смотритель маяка
Регистрация: 11.03.2013 Последняя активность: 21.05.2025 10:22
Сказал(а) спасибо: 257
Шляпа какая то, уносите. Следующий!
Странные фонарики...на каких диодах?
смотритель маяка
The 120W Ehpro Cold Steel 100 TC Box MOD is widely compatible with single 21700/20700/18650 battery and supports 120W max output with high performance PWR/TEMP/CURVE/VOLT/BYPASS working modes.
![]() The Smoant Pasito Pod System Kit comes with three types of coils, Top filling design and top adjustable airflow construction to bring you great convenience, together withANT constant output chip, to deliver superb flavor for you. ![]() The 220W Vaporesso GEN TC Kit keeps providing you the extraordinary flavorful punch from the first start of firing. The intelligent system the GEN MOD equipped will make it easier to operate and the human centered user interface function provide a brand-new way to enjoy vaping. ![]() The Rincoe Ceto SE Kit adopts 650mAh built-in battery and 2ml juice capacity. The side juice refilling system and PCB Nano coating is best for leak-proof too. The Rincoe Ceto SE keeps the physical button for switch on/off the device. ![]() The Rincoe Neso X Pod Kit consists of 350mAh battery and 1.8ml e-juice capacity. In addition with the easy side filling, no button design and multiple protections, The Neso X Pod Kit provide you great convenience. ![]() The Rincoe Mechman MOD works with a single 18650 battery to provide a max output of 80W. Two mesh coils are available for you—single mesh 0.25ohm, and Dual mesh 0.2ohm—to bring you a longer lifespan and purer taste. ![]() Best electronic cigarettes at buybest, free shipping, and fast delivery! Best Pod Vape Kits Rated on Reddit 2019: https://www.buybest.com/art... |
Hey guys, the Japan Warehouse Clearance Sale is coming! Up to 60% sales,3-7 fast delivery and Zero Custom Duties.
![]() Innokin Endura T18 Starter Kit ![]() Original Price:$26.68 Discount Price:$13.34 Vapefly Galaxies MTL RDTA ![]() Original Price:$26.65 Discount Price:$15.99 Eleaf iCare Starter Kit 650mAh ![]() Original Price:$14.89 Discount Price:$7.45 Find more great details: https://www.buybest.com/eve... Note: This item can only be shipped to Japan address, 3-7 days fast delivery, zero customs duties! |
смотритель маяка
было бы продуктивнее впаривать вейпы на форуме для вейперов... то, что эта хренотень тоже имеет источник питания не означает, что она фонарь и с ней надо бежать именно на фонаревку... не, ну можно на фонаревке и зимней резиной для Таврии торговать, кто то даже может и купит ее.. Но это не значит, что она нужна тут всем...
смотритель маяка
Торгуй своими свистками в электричках, тут нужны фонари ФОНАРИ
, если бы я хотел вейпы, я бы сидел на форуме вейперов
Here comes the new round of our Vape flash sale. Product list as below. Ends at 16:00 PM on June.14(PST).
![]() SMOK GX2/4 TC Kit with TFV8 Big Baby Tank WISMEC SINUOUS FJ200 4600mAh Kit with Divider Tank SMOK GX350 Kit With TFV8 Tank 80W Joyetech CUBOID Lite TC Box MOD 320W SMOK G320 Marshal TC Box MOD Joyetech UNIMAX 25 Starter Kit Thank you & enjoy shopping at www.buybest.com cheap vape starter kit and cheap vape accessories at BuyBest. |
Hi guys, the father's day is coming! 10% OFF sitewide, pick the best gift for your father.
![]() Sale Time: June 11ST-18Th, 2019(PST) Find more details at: https://www.buybest.com/col... cheap vape accessories, best vape starter kits at BuyBest! |
Here comes the new round of our Vape flash sale. Product list as below. Ends at 16:00 PM on June.17(PST).
![]() 320W SMOK G320 Marshal TC Box MOD 218W Smoant Cylon TC Box MOD 200W GeekVape Aegis Legend Kit with Aero Mesh Version 220W Vaporesso Polar TC Kit with Cascade Baby SE Tank 157W VOOPOO DRAG Resin TC Box MOD Joyetech CUBIS Pro Mini Tank Atomizer Thank you & enjoy shopping at www.buybest.com cheap vape starter kit and cheap vape accessories at BuyBest. |
17
смотритель маяка
Дорогой продавец! Ну как тебе еще объяснить... Это форум по осветительной технике и здесь традиционно принято торговать фонарями и сопутствующими товарами: аккумуляторами, зарядками, комплектующими и т.п. Я понимаю, что на профильном форуме по вейпам есть и другие магазины и они создают конкуренцию, но твои потуги торговли этими штуками здесь, сродни попыткам торговать автозапчастями на продуктовом рынке. Конкуренция минимальна, ровно как и шанс найти покупателя. Давай фонари завози уже!
| Поблагодарили: 2 раз(а) |
Alex G (14.06.2019), Tankist_20 (14.06.2019)
Exploder (16.06.2019)
The Innokin Gala Pod Kit, comes with one Plex3D mesh Coil pod of 2ml capacity, best for Mouth to Lung vaping, and the other Refillable Ceramic Pod of 2ml capacity, best suitable for nic-salt and CBD e-juice.
![]() This Squid Industries Squad 3-in-1 Pod Kit will definitely stand out among hundreds of new electronic cigarette vape kit, due to its revolutionary design and new technology. ![]() OBS Cube X Kit comes with a fashionable and unique appearance, and a larger size than other cube series. Two kinds of coils available for you—0.2ohm M1 mesh coil and 0.15 ohm. And it is is powered by 18650 battery for the long lasting vaping time. ![]() Eleaf Tance Max Vape Kit comes with a built-in battery 1100mAh Tance Battery to reach a max output of 20W, and 4ml/2ml Tance Max Cartridge Tank, available in GS Air M 0.6ohm Coil Head and GS Air S 1.6ohm to meet your different demand. ![]() Here introduce a Eleaf Tance cool pod system kit. Designed with a stylish appearance, Eleaf Tance Kit will bright you a great vaping experience. It adopts ergonomically-friendly mouthpiece which will fits your lip much better. The built-in 580mAh battery can easily fulfill your daily use. Besides, it supports type-c quick charging, that you can take it within yourself everywhere. ![]() The OVANTY Falcon is a new multi-functional pod kit with 950mAh battery capacity and 1.8ml refillable pod. 2019 Top high-end workmanship Pod system comes with high quality Tempered Glass 0.69’ OLED screen. Get the flavor and cloud with the OVANTY Falcon Pod Kit. ![]() Vvild V0 Pre-filled Pod System Kit adopts air and e-liquid separation and triple silicone seal design to prevent e-liquid leakage, and comes with 350mAh inbuilt battery and 2ml pre-filled Nic vape juice cartridge, made of lightweight aluminum materials, which will grip comfortable. ![]() Best electronic cigarettes at buybest, free shipping, and fast delivery! Best Pod Vape Kits Rated on Reddit 2019: https://www.buybest.com/art... |
20
смотритель маяка
