Просмотров в теме 1538   Ответов в теме 0   Подписчиков на тему 2   Добавили в закладки 0
Старый 27.04.2019, 17:21 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Weltool INR16320 750mAh 123A USB (Black-red)
Official specifications:
  • Core’s Capacity: (typ.) 750mAh
  • Resistance: <85mOhm
  • Output Voltage: 3.0V
  • Maximum Continuous Discharging: 1.4A
  • Charge: 0.33A (Micro-USB port charging??1A?0.5A?Battery Charger?
  • Charging Protection: 4.3±0.05V
  • Discharge Protection: 2.5±0.1V
  • Usage: More than 300 charging cycles, the battery still has 80% capacity.
  • Status Indicator: Red:Charging Blue:Complete
  • Temperature during charging: 0-45°C
  • Temperature during discharging: -20-50°C
  • Size: 16.6±0.2mm (Dia.) , 34.9±0.1mm (Length)
  • Weight: 18.5±0.5g
This is a CR123 substitute with build in USB charger.
There is read and blue leds below the white washer to show charge status.
It is very obvious that this battery is electronically regulated, they voltage stays at 3V with any load up to maximum. There is also a protection build in, that turns off the output when the battery is empty.
Conclusion
There is no perfect rechargeable substitute for a CR123 battery, but this battery comes close.
Differences to a CR123: Battery is 2.6mm longer, voltage will stay at 3V, i.e. battery indicator will not work and equipment that count on voltage drop at high current may get too hot.
Notes and links
The battery was supplied by Weltool for test.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
Время генерации страницы 0.09690 секунды с 15 запросами
