Просмотров в теме 1934   Ответов в теме 1   Подписчиков на тему 2   Добавили в закладки 0
Старый 15.04.2019, 17:40 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Vapcell INR21700 4500mAh (Red) 2019
Official specifications:
  • Model: INR21700
  • Size: 21.5*70.8mm
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50v
  • Typical Capacity: 4500mAh (0.2C discharge)
  • Min capacity: 4400mAh (0.2C discharge)
  • Weight: Max:72g
  • Internal resistance: Max:15mOhm
  • Standard Charge: 1500mA, CCCV 100mA cut-off
  • Quick Charge Current: 3000mA
  • Max Continuous Discharge Current: 20A
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: -20°C~75°C
  • Storage Temperature -5°C~35°C
  • Storage Humidity: <75%RH
This is a high current battery in 21700 size with good capacity.
The two tracks matches fairly well and capacity only goes down slowly with load.
Conclusion
This looks like a good battery, it can handle a fairly high current and has good capacity.
Notes and links
Graphical comparison to 18650 and other batteries
Graphical comparison to 26650 and other larger batteries
Table with all tested LiIon batteries
blindnick (15.04.2019)
Старый 15.04.2019, 18:19   2
По умолчанию Re: Test/review of Vapcell INR21700 4500mAh (Red) 2019
Давненько не видел газового клапана с отрывом днища...
Время генерации страницы 0.09992 секунды с 15 запросами
