Просмотров в теме 2002   Ответов в теме 0   Подписчиков на тему 2   Добавили в закладки 0
Старый 26.03.2019, 19:03 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Vapcell INR21700 4200mAh (Green) 2019
Official specifications:
  • Model: INR21700
  • Size: 20.5*70.2mm
  • Nominal voltage: 3.6V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50V
  • Typical Capacity: 4200mAh (0.2C discharge)
  • Min capacity: 4000Ah (0.2C discharge)
  • Weight: Max: 70g
  • Internal resistance: Max: 11mOhm (AC 1kHz)
  • Standard Charge: 1500mA,CCCV 100mA cut-off
  • Charging Time: 4hours(standard charge)
  • Quick Charge Current: 3000mA
  • Max Continuous Discharge Current: 30A
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: -20°C ~ 75°C
  • Storage: Temperature -5°C ~ 35°C, Humidity <75%RH
  • Standard environmental condition: Temperature: 23±5°C, Humidity: 45-75%RH
This is a high current 21700 cell with good capacity.
The two cells match perfectly, but the capacity is slight low.
Something went wrong during my discharge and the B battery melted my battery holder, but as can be seen it did not get that hot (Temperature sensor is a bit slow to register temperature). The A battery got hot enough to stop the discharge.
Conclusion
This is a good quality high current battery, but the 30A may be a bit optimistic for continuous discharge.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Время генерации страницы 0.08712 секунды с 15 запросами
