2236
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
BLD 18650 3800mAh USB (Green)
![]() Official specifications:
![]() A USB rechargeable LiIon battery, based on a 18500 cell with 3800mAh, no way ![]() ![]() ![]() ![]() ![]() ![]() ![]() The capacity is lower than I expected and it cannot handle much current either, but at least the two tested batteries are equally bad. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() This is charging with a normal LiIon charger. ![]() This is charging from the USB connector with a 5V supply, the two charge circuit is not perfectly matched in voltage, but easily withing the usual tolerances. Conclusion This is not exactly good batteries, they are rather bad with only 700mAh and only up to about 2A current. The USB charging works and do not need a cable. They may be usable for some low power 18650 devices where USB charging is needed, but there is much better batteries with build in USB charger. Notes and links How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries Graphical comparison to 18650 and other batteries Table with all tested LiIon batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
| Поблагодарили: 3 раз(а) |
Регистрация: 27.01.2018 Последняя активность: 11.07.2023 20:20
Сказал(а) спасибо: 1003
