Просмотров в теме 1998   Ответов в теме 1   Подписчиков на тему 2   Добавили в закладки 0
Старый 24.12.2018, 15:39 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Vapcell INR20700 3100mAh (Golden) 2018
Official specifications:
  • Model: INR20700
  • Size: 20.5*70.2mm
  • Nominal voltage: 3.6V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50V
  • Typical Capacity: 3200mAh (0.2C discharge)
  • Min capacity: 3100Ah (0.2C discharge)
  • Weight: Max: 66g
  • Internal resistance: Max: 10mOhm (AC 1kHz)
  • Standard Charge: 2000mA,CCCV 100mA cut-off
  • Charging Time: 3hours(standard charge)
  • Quick Charge Current: 4000mA
  • Max Continuous Discharge Current: 30A
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: -20°C~75°C
  • Storage: Temperature -5°C~35°C, Humidity <75%RH
  • Standard environmental condition: Temperature: 23±5°C, Humidity: 45-75%RH
This is a 20700 high current battery.
The discharge curves for the two cells tracks nicely, capacity drops a bit with load as expected. The 30A rating looks good enough.
Conclusion
This is a good high current cell in the 20700 size.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 26650 and other batteries
Старый 24.12.2018, 15:45   2
По умолчанию Re: Test/review of Vapcell INR20700 3100mAh (Golden) 2018
Долой илону!
Время генерации страницы 0.09707 секунды с 15 запросами
