Просмотров в теме 1259   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 26.11.2018, 09:59 Автор темы   1
Аватар для desert.snake
По умолчанию Продам Malkoff Hound Dog Super
Получил на днях, новенький, отличный фонарик,
но в данный момент новые детали для компьютера важнее.
стоит около $ 330 с учётом доставки
https://malkoff-devices.mys...
отдам за 15000 р ($ 230)
описание
Malkoff Devices Hound Dog Super Flashlight. The Cool Variant produces produces 1700 (measured) Out The Front Lumens at turn on and 1600 (measured) continuous Out The Front Lumens.
The Flashlight utilizes a 7 degree Optic. The Lux is 75,000 at one meter (cool). This is a real long distance spotter with decent spill. The LED is a Cree XP-L 6200K. It will easily light objects at 1500+ feet. It has a High/Low Switch installed and ready to go. The High/Low output is controlled by head rotation. The low output is approximately 80 lumens on two rechargeable Li-ion batteries and 120 lumens on four primary CR123 batteries. The On/Off switch is a forward clicky with momentary function.
The input voltage is 7 - 12 Volts.
The current draw at 7.4v is 2600ma.
The current draw at 12v is 1600ma.
It can use four primary lithium CR123 batteries or two to three Li-ion rechargeable batteries. The runtime on high is approximately 1 hr (on high) with two 3400 mah 18650's. Four CR123 primaries will provide about 30 minutes full output runtime.
With the MD4 Body it is 8.5 inches (22 см) in length with a 1 inch (2,6 см) body diameter and 2.35 inch (6 см) head diameter.
It is constructed of 6061 T6 Aluminum with Type III Black HA finish. It is fully O-Ringed for weather tightness. A shatter resistant Ultra Clear (AR coated) Acrylic Lens is included.
This Head was designed for rugged service from the ground up. It is fully potted to stand up to rough service and recoil.
график отсюда http://www.candlepowerforum...
правда там только модель с 4000К диодом,
но в целом должно быть ~ так же, отлично работает с телом на 1*18650
фото
[Исправлено: desert.snake, 18.11.2018 в 10:52]
Время генерации страницы 0.07863 секунды с 15 запросами
