2787
ACEBEAM H30 provides an unparalleled output from Ultra-Low 3 lumens to Turbo- max. 4000 lumens widely used from night reading to outdoor searching, making ACEBEAM H30 the most powerful headlamp. The equipped Type-C rechargeable function with Triple times charging speeds makes H30 much more convenient to charging the 21700 5100mAh battery inside the tube without taking the battery out. Being fitted with a CREE XHP70.2 LED white light for a better color rendering, the additional CREE XPE2-R2 630nm Red light and the option light CREE XPE2-G3 530nm Green light, Nichia 276A 365nm UV, Nichia 219C CRI 90+ allows the capability for any mission such as outdoor hunting, and easily protects the night vision. The special SOS for an emergency can even last 72 hours without turning off the light. The compact headlamp H30 is ideal for demanding sports such as hunting, fishing, cycling, camping, backpacking, reading and all night activities.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() More information, pls click http://www.acebeam.com/h30 sales@acebeam.com
www.acebeam.com |
| Поблагодарили: 2 раз(а) |
vorsmann (15.01.2025), Алексей Михайлович (09.11.2018)
If you want an absurdly bright, well-built, durable small brick on your forehead with multiple outputs (combined with additional color LEDs or high CRI), this ACEBEAM H30 is exactly the right headlamp. It is perfect for extended nighttime navigation, route finding, wilderness night work, and outdoor activities.
Learn more: https://www.acebeam.com/h30 ![]() cs@acebeam.com |
| Поблагодарили: 3 раз(а) |
