1757
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Charger Leise NiMH 2 slots LS-U2C
This is a fairly simple dual NiMH charger powered from USB. ![]() ![]() ![]() ![]() It arrived in a cardboard box with brand name and not not much else on it. ![]() The box contained the charger, a usb cable and a instruction sheet in Chinese. ![]() The charger is usb powered with a micro usb input. ![]() There is a led for each slot that will light up for the 9½ hour a charge takes. ![]() The specifications are on the bottom of the charger. ![]() The charger uses the classic two level construction for AA/AAA batteries. ![]() Measurements
![]() The battery is nearly charged fully in about 9½ hour with a fairly low charge current. ![]() This cell is charged fully, again in 9½ hour. ![]() The pro is far from fully charged, the charger again used 9½ hour. ![]() Not much surprise, 9½ hour charging and the charger stops. ![]() The AAA also gets 9½ hour at a lower current and is overcharged a bit. ![]() The full eneloop gets 9½ hour, that is about 9 hours of overcharge. ![]() With two batteries each battery gets the same current and the same 9½ hour. ![]() M1: 40.5°C, M2: 40.5°C, HS1: 97.0°C The charger use a linear regulation and need to burn some power, this means there is a rather hot location on it. ![]() Being a very simple charger I could draw the current profile. There is no regulation. ![]() The charger do not have any controller that need time to initialize, but starts immediately Conclusion The charger is a very small size, due to this is can be useful, but is is very slow and use a timer based termination. The low charge current means that damage to a battery is fairly limited and the charger can be used sometimes, but it is a bad idea to use this charger as the main charger for NiMH. I will rate it usable. Notes Here is an explanation on how I did the above charge curves: How do I test a charger
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
m72 (24.06.2018)
