Просмотров в теме 1767   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 19.06.2018, 18:33 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Ansmann D 10000mAh 5030642 (Silver)
Official specifications:
  • Nominal voltage: 1.2V
  • Max. charge voltage: 1.5V at 0.1C
  • Nominal capacity: 10000mAh
  • Minimum capacity: 9300mAh at 0.2C
  • Minimum capacity: 8500mAh at 1C
  • Max. continuous discharge current: 10A
  • Standard charge: 1000mA
  • Quick charge: 2750mAh
  • Fast charge: 5000mAh
  • Recommended charge termination: -DV=0-5mV, DT/minute=0.8..1°C, T=45-50°
  • Internal resistance: <15mOhm at 1kHz
  • Cycle life: 500 cycles
  • Self discharge: >60% charge remaining after 28 days This is from the datasheet with the correct type number and a photo of the battery and pack saying "Low self discharge"
Maximum temperature raise at different discharge currents: 1A:+0,9°C, 2A:+0,0°C, 3A:+2,1°C, 5A:+2,8°C, 7A:+5,2°C, 10A:+8,9°C, 15A:+14,1°C
This is high capacity D cells, the capacity is around 4 AA cells.
There is some capacity difference, most at the start of the test after a couple of cycles it is reduced. Only one of the cell lives completely up to the rating.
Conclusion
This D cell has some real capacity, but I wonder about the low self discharge.
Notes and links
Compare to AA/AAA batteries: Alkaline/NiMH/Lithium
[Исправлено: HKJ, 19.06.2018 в 18:34]
m72 (19.06.2018)
Время генерации страницы 0.07912 секунды с 15 запросами
