2810
![]() Регистрация: 08.08.2011 Последняя активность: 10.06.2025 04:25
Поблагодарили: 159 раз(а) в 53 сообщениях
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() M200 magnetic charging flashlight LED: CREE XP-L Max output: ANSI 950 Lumens / 1200 LED Lumens Max runtime: Few months Max beam distance: 184 meters Max peak beam intensity: 8500cd Waterproof: IPX-8 Impact resistant: 1 Meter Battery: 1×18650 , 2x CR123A , 2x RCR123A Rated Range: 2.7V ~ 8.4V Dimension: Length 104.5mm / 411 inch Head diameter 23.5mm / 0.93 inch Body diameter 22.0mm/0.86 inch Weight: 44g / 1.55oz (without battery) Accessories: USB magnetic charging cable, clip, lanyard, magnet replace rubber pad, Operator’s manual, Spare O-ring Operation Battery installation & Replace magnet:Insert the battery into the flashlight,the battery positive pole toward the light head. Ensure batteries are inserted correctly, the flashlight will not operate with incorrectly inserted batteries. Ensure when the light turning on,the beam is directed away from the eyes. When take the light with Bankcards(magnetic) or Cell phone,should replaced Magnet with rubber pad. Flashlight turning on/off: When the flashlight was OFF status: Press the side switch to memorized brightness level. Press and hold the side switch 0.5 second,to low mode. Quickly double press side switch to turbo mode. Quickly triple press side switch to strobe mode. When the flashlight was ON(any mode) status: Press and hold the side switch 0.5 second to turn off. Brightness & mode selection: Brightness level: Press side switch to Low-Mid-High-Turbo, cycle. Special modes: Quickly double press the side switch to Sub-level(i.e between L1 & L2), turn off memorized the last brightness. Quickly triple press the side switch to Strobe (S1), then double-click to switch S1/S2/S3 mode, Press side switch back to previous brightness level. Power indicator Every time press the switch turn on, the side indicator(blue or red light) will be 5 seconds to display the battery power. Constant Blue: battery power in 100%~80%, Flashing Blue: battery power in 80%~50%, Constant Red: battery power in 50%~20%, Flashing Red: battery power below 20%. Low voltage indication When the battery voltage drop down lower than 3.3V, indicator flash twice every 10 seconds. Battery voltage drop down to lower than 3V, indicator flash 3 times every 10 seconds. Location indicator & Lock-out function: When turn off the flashlight, press switch 1.5 seconds, location indicator switch on and lock-out function activation at the same time, Press button onl can switch the indicator on/off. The indicator light flash every second, locate the flashlight, easy find the flashlight in the dark quickly. Hold press the switch 1.5 seconds, switch button unlock and enter into low mode. Charging instructions and notices In charging, the red indicator constant light on, when battery almost full charge, indicator change to constant blue light. When the red indicator flash, please check battery contacts good or not. Warning: Rechargeable function only for one 18650 (3.6/3.7V) rechargeable lithium battery! Please make sure the battery is correctly insert, otherwise it will damage the charging system. Features Super bright & latestCREE XP-L LED, Max 1200 LED lumens. High-Performance, High-Efficiency and energy conservation. Durable aluminum vacuum plating reflector, Efficiency reflection, perfect beamshot, excellent structure and temperature resistance. Built-in magnetic charging system, fast charge and convenient. Rugged indestructible aluminum body with anti-scratching type III hard anodization Multi-level dissipating heat designand new copper starboard, excellent heat dissipation. Flashlight head integrated construction, high thermal conductivity. Side switch button to transferring mode user-friendly interface to adjust output. Eightoutput levels and three Strobe, suitable for different environment. Wide input range provides more choices of batteries. High efficiency driver circuit, no visible flash in any mode. Automatic memory function, remember last used setting and can be preset to specific output mode for instant access. New intelligent temperature control technology for headlamp stable and safe use. Reverse polarity protection, to protect from improper battery installation. 12.Low-voltage prompts function, the light will flash when the battery is low,remind user replace the battery on time. 13.When turn off, hold press button to activate lockout function. Avoid light turn on by unexpected. 14.When light lockout, location indicator will flash, easy get the light in dark. Magnetic tail, can be used in many special occasions, use as candlelight, etc. www.skilhunt.com M200 flashlight |
witalen (19.06.2018)
