2088
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Charger Basen BO-1
This is a fairly simple single cell LiIon charger from Basen. It arrived in a cardboard box with a lot of specification on it. ![]() The box contained the charger, a usb cable and a instruction sheet. ![]() The charger is usb powered with a micro usb input. ![]() There is only one button and a couple of leds. The button will change selected current, default is 0.5A. ![]() During power on all the leds will shortly turn on. During charge the blue leds are animated and only one green led is on. ![]() The specifications are on the bottom of the charger, but rather hard to read. ![]() The charger uses the classic slider construction and will handle batteries from 28mm to 70.7mm, this will give problem with the longest protected cells. ![]() The charger can handle up to 70mm long batteries, Measurements
![]() A nice CC/CV charge curve with termination current of about 35mA. The charge voltage is at the top of the allowable range. ![]() ![]() The two other batteries also look nice. ![]() There is no problem with this old cell. ![]() Using 0.5A also works fine. ![]() The low termination current is fine for smaller cells. ![]() And also for old worn out cells. ![]() The 2A current is only maintained for a short time due to voltage limitations, then it will slowly drop. The charging is faster than 1A charging. ![]() Adding 0.5ohm resistance in series with the power supply to simulate a long cable or weak supply shows that the charger will reduce usb and charge current, but the charging works fine. ![]() M1: 39.4°C, M2: 51.9°C, M3: 58.5°C, M4: 52.2°C, HS1: 60.0°C ![]() Being a fairly simple charger I could draw the current profile. ![]() The charger is very fast to start, it only needs about 1 seconds. ![]() It is possible to change current at any time. Conclusion The high charge voltage and low termination current will mean fully charged cell, but will cost a bit lifetime for the batteries. I like the simple user interface and adjustable tray, it is easy to use and means that the charger can handle most LiIon battery sizes. I will rate it as good. Notes Here is an explanation on how I did the above charge curves: How do I test a charger
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
