2655
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
GP Recyko+ Pro U411
GP has a line of both chargers and batteries, this charger includes a set of NiMH batteries and as can be seen on the label GP means the charger is free. This is reflected in the naming of the pack: it is only named for the batteries. The charger can charge two or four AA/AAA batteries at a time and is usb powered. I got the charger in a partial clear plastic pack. The pack contains the charger, a usb cable, 4 2000mAh pre-charged NiMH AA batteries and a instruction sheet. The batteries will be covered in their own review. ![]() The charger has a micro usb connector for power input. ![]() There are two led indicator lamps, flashing when charging and steady when not. The charger is rated for 1A input, this is a bit high for a total charge current of 0.6A. Notice the hole in the bottom, this makes it easy to remove the batteries. The charger has the typical two level slots used for AA/AAA batteres. ![]() Measurements
![]() The charger will charge for nearly 8 hours and then switch to 50mA tricke charge, charge current will vary with battery voltage. ![]() The two other slots looks the same. ![]() When using high capacity batteries the fixed charge time is not enough to fill the batteries. ![]() This charger do not care about the condition of the batteries, they call get the same charge. ![]() These batteries have to much capacity to be filled. ![]() An AAA cell has less capacity, the charger handles that by lower charge current and using the same charge time. These batteries are just about filled. ![]() Putting full batteries in the charger is a bad idea, they get another full charge. ![]() 2 or 4 batteries do not matter for charge speed or algorithm. ![]() Power consumption is about 0.7A, not the rated 1A, but this will depend on battery voltage. ![]() M1: 37,4°C, M2: 37,6°C, M3: 37,4°C, M4: 37,1°C, HS1: 43,2°C ![]() M1: 46,4°C, M2: 49,6°C, M3: 49,7°C, M4: 46,2°C, HS1: 52,3°C When batteries are full the temperature will raise and stay that way for some time while waiting for the timer termination. ![]() The charger is fairly fast to start. The there is only one charge circuit it will time share between the two sets (1+2 and 3+4). Conclusion This is a very simple charger with timer based control, it works fine for empty 2000mAh AA cells or empty 900mA AAA cells, but not for anything else. I will call the charger usable. Notes Here is an explanation on how I did the above charge curves: How do I test a charger
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
