Просмотров в теме 1572   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 18.04.2018, 19:02 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Vapcell NCR20650 3000mAh (Purple)
Official specifications:
  • Model: NCR20650
  • Size: 20.0*65.1mm
  • Nominal voltage: 3.6V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50V
  • Typical Capacity: 3000mAh (0.2C discharge)
  • Min capacity: 2900mAh (0.2C discharge)
  • Weight: Max:56g
  • Internal resistance: Max:10mOhm
  • Standard Charge: 2000mA,CCCV 100mA cut-off
  • Charging Time: 3hours(standard charge)
  • Quick Charge Current: 4000mA
  • Max Continuous Discharge Current: 30000mA
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: -20°C~70°C
  • Storage: Temperature -5°C~35°C, Humidity <75%RH
  • Standard environmental condition: Temperature: 23±5°C
  • Humidity: 45-75%RH
A 20650 cell, this means slightly larger diameter than 18650, but same length. This cell is a high current cell with good capacity.
The discharge curves looks nice, nearly constant capacity at any current.
At high current the cell do get warm, here I had to stop the discharge due to temperature.
Conclusion
This is a good high current cell with fairly decent capacity, in performance it is close to the best 18650 cells.
Notes and links
The batteries was supplied by Vapcell for review.
blindnick (18.04.2018)
Время генерации страницы 0.10237 секунды с 15 запросами
