Просмотров в теме 2213   Ответов в теме 2   Подписчиков на тему 2   Добавили в закладки 0
Старый 11.04.2018, 12:27 Автор темы   1
Аватар для Acebeam Light
Последняя активность: 09.01.2026 18:01
Сказал(а) спасибо: 12
Отправить сообщение для Acebeam Light с помощью MSN Отправить сообщение для Acebeam Light с помощью Yahoo Отправить сообщение для Acebeam Light с помощью Skype™
По умолчанию 2018-April High CRI Mini Torch EC65 Releasing
A new small and exquisite Type-C rechargeable EDC lamp EC65 is going to come out.
ACEBEAM EC65 is a hand held flashlight that can be easily fitted into the palm of hand. There are two different light sources for this EDC lamp: 4* CREE XPL LEDs or 4*Nichia 219C LEDs.
Different from the previous models, ACEBEAM EC65 adopts TIR optics: all new acrylic lens with a honeycomb to produce highly efficient optics with a huge variety of beam shapes. 4* CREE XPL LEDs verion is equipped with smooth TIR lens with an extra long range beam of 207 meters. 4*Nichia 219C LEDs version is featured by an orange peel TIR lens with a max beam distance 142 meters.
The toughened ultra-clear tempered glass lens with anti-reflective coating gives EC65 about 98.3% transmittance, makes the flashlight truly usable in every condition.
The five different brightness levels can be quickly selected by the functional switch on the side continuously: Firefly - Low - Mid - High - Turbo which can be widely used for reading, searching, camping, caving, rescuing, etc.. From the firefly mode 20 lumens to Turbo mode 3800 lumens for 4* CREE XPL LEDs verion, and firefly mode 20 lumens to Turbo mode 2200 lumens for 4*Nichia 219C LEDs version, EC65 has the max running time about 3.8 days at the lowest brightness 20 lumens for both versions.
The built-in charging function charges 21700 or 18650 Li-ion battery through the newest Type-C USB charging port, which is with 3 times speed of the traditional Micro-USB input. There is an indicator beside the side switch, when the indicator shows red, it means the flashlight is under charging; and when the indicator shows green, means the flashlight is fully charged and prepared well for its mission.
EC65 is made up of durable aircraft grade aluminum with Premium Type III Hard Anodized Anti-abrasive finish. Also thanks to the excellent knurling throughout the surface of the entire light, ensures EC65 firm grip even with water or sweat in hand when you most need it.
There is no need to worry at all if you need to use EC65 in wet condition, because it can even be immersed in a depth of about 5 meters without getting damaged.
EC65 is also capable of standing up securely on a flat surface to use in “candle mode”.
EC65 is a very powerful flashlight in a compact and lightweight size. Overall length is 114.5mm with 30mm head diameter and 27mm tube diameter, weight is 82g excluding batteries.
EC65’s relatively tiny size and very bright beam make it a good choice for many different outdoor applications.
sales@acebeam.com
www.acebeam.com
Acebeam Light вне форума   Ответить с цитированием Вверх
nsk1979 (11.04.2018)
Старый 11.04.2018, 13:40   2
По умолчанию Re: 2018-April High CRI Mini Torch EC65 Releasing
Запасные сменные лампочки в комплекте? Из описания - хочешь поярче xpl, хочешь получше - nichia. Или как всегда - выбирай до покупки и на всю жизь ? Небось и поменять лампочку просто так не получится - мажь пасту, паяй диоды...
Старый 11.04.2018, 14:02   3
nsk1979
Аватар для nsk1979
Последняя активность: Сегодня 11:55
Сказал(а) спасибо: 1524
Скорее всего стандартная звезда под квад. Можно купить в сборе с СИД у Хэнка. Главное чтобы с управлением не накосячили.
Время генерации страницы 0.09470 секунды с 15 запросами
