Просмотров в теме 1999   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 17.03.2018, 19:27 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Golisi IMR21700 3750mAh S35 (Black)
Official specifications:
  • Size: 21 x 70mm
  • Model: 21700
  • Capacity: 3750mAh
  • Constant Current: 40A
  • Nominal Voltage: 3.7V
  • Charging cut-off voltage: 4.20±0.05V
  • Internal resistance: 30mOhm
  • Standard charging current: cc/cv(<=3A)
  • Cycle times: >800
  • Operate temperature: Charging: 0°C ~ 45°C), Discharging: -20°C ~ 60°C
A high current with fairly high capacity 21700 cell.
The two cell has different capacity, but both has fairly constant capacity even at high load. One cell is close to stated capacity at low low, the other is a bit low.
Temperature is acceptable at 20A
But at 20A I had to stop the discharge due to heat.
Conclusion
The current and capacity is good, but I do not like that the cells have different capacity.
Notes and links
The battery was supplied by Golisi for review.
blindnick (17.03.2018), Edit_Thor (17.03.2018), m72 (17.03.2018)
Время генерации страницы 0.08390 секунды с 15 запросами
