Просмотров в теме 1782   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 05.02.2018, 18:46 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Vapcell INR18650 2400mAh (Purple)
Official specifications:
  • Model: INR18650
  • Size: 18.3*64.8mm
  • Nominal voltage: 3.6V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50V
  • Typical Capacity: 2400mAh (0.2C discharge)
  • Min capacity: 2300mAh (0.2C discharge)
  • Weight: Max:46g
  • Internal resistance: Max:10mOhm
  • Standard Charge: 1000mA,CCCV 100mA cut-off
  • Charging Time: 3.5hours(standard charge)
  • Quick Charge Current: 4000mA
  • Max Continuous Discharge Current: 30000mA
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: -20°C~70°C
  • Storage: Temperature -5°C~35°C, Humidity <75%RH
  • Standard environmental condition: Temperature: 23±5°C
  • Humidity: 45-75%RH
This is a high current cell with not that much capacity.
The two cells tracks nicely and they can deliver 30A.
I had to skip the temperature curves, I forgot to replace the battery (It last about a year).
Conclusion
The battery is a bit low in capacity, but it can deliver a lot of current.
Notes and links
The batteries was supplied by Vapcell for review.
avglushkov (05.02.2018), m72 (05.02.2018), Анатолий. (05.02.2018)
Время генерации страницы 0.07571 секунды с 15 запросами
