Просмотров в теме 2355   Ответов в теме 1   Подписчиков на тему 2   Добавили в закладки 0
Старый 26.01.2018, 20:06 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of GP ReCyko+ AA 2700mAh (Green)
Official specifications:
  • Nominal voltage: 1.2V
  • Typical capacity: 2600mAh at 500mA discharge to 1.0V at 20°C
  • Nominal capacity: 2500mAh
  • Lifetime: 6 years or 300 cycles
  • Low self discharge
  • Recommended discharge current: 250 to 7500mA
  • Fast charge: 1250mA to 2500mA with -dv/dt
  • Service life: >500 cycles (IEC standard)
  • Internal resistance 18mOhm (range 14-28mOhm) at 1000Hz
  • Ambient temperature range: Standard charge 0°C ~ 45°C, Fast charge: 10°C ~ 45°C, Discharge: -20°C ~ 50°C, Storage: -20°C ~ 35°C
Maximum temperature raise at different discharge currents: 1A:+1,2°C, 2A:+3,4°C, 3A:+5,9°C, 5A:+11,1°C, 7A:+16,3°C, 10A:+23,0°C
Fairly standard NiMH discharge curves, the cell are not matches completely. They have a lot of capacity at low current draw and as usual the capacity goes down with load. At very high current (Above 5A) the cells need to be warm for best performance.
Conclusion
These batteries has good performance, especially at low current draw.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
m72 (26.01.2018), nomorewar (26.01.2018), Zexx (20.02.2018)
Старый 26.01.2018, 23:28   2
nomorewar
Последняя активность: 11.01.2026 20:00
Сказал(а) спасибо: 441
По умолчанию Re: Test/review of GP ReCyko+ AA 2700mAh (Green)
Thanks. This cells even a little bit better than eneloop or ladda on low current. Anyway ladda cheaper)
nomorewar вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.08998 секунды с 15 запросами
