Просмотров в теме 2066   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 23.12.2017, 19:03 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Enercig 26650 5200mAh EC-265HC (Blue)
Official specifications:
  • Type. Capacity: 5200 mAh
  • Weight: 94 g
  • Diameter: 26.5 mm
  • Height: 66.5 mm
  • Rated voltage: 3.6 volt
  • Max. Charge Voltage: 4.2 Volt
  • End Voltage: 3.0 Volt
  • Max. Charging current: 3.0A
  • Max. Discharge current: 3.5C 18 A with thermal fuse at 80°C
  • Max. Discharge current:15 A 3C without temperature protection 80°C
  • Protection (PCB): No
This is a high current 26650 from German
The battery has fairly constant capacity with load and the 15A rating looks fine enough, but there is some difference between the two batteries.
At 15A the temperature is warm, but still reasonable.
Conclusion
The cell has very good performance at high current for a 26650 and the capacity is also fairly good.
Notes and links
The batteries was supplied by ENERDan for review.
Время генерации страницы 0.07429 секунды с 15 запросами
