Просмотров в теме 1829   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 19.12.2017, 19:37 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Vapcell INR21700 3100mAh (Purple)
Official specifications:
  • Model: NCR21700
  • Size: 21.0*70.2mm
  • Nominal voltage: 3.6V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50V
  • Typical Capacity: 3100mAh (0.2C discharge)
  • Min capacity: 3000mAh (0.2C discharge)
  • Weight: Max:68g
  • Internal resistance: Max:8mOhm
  • Standard Charge: 2000mA,CCCV 100mA cut-off
  • Charging Time: 3hours(standard charge)
  • Quick Charge Current: 4000mA
  • Max Continuous Discharge Current: 35000mA
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: -20°C~70°C
  • Storage: Temperature -5°C~35°C, Humidity <75%RH
  • Standard environmental condition: Temperature: 23±5°C
  • Humidity: 45-75%RH
One of the new slightly larger batteries, this one with fairly low capacity, but very high current capability.
Good tracking, expect a small capacity difference. The batteries has nearly constant capacity op to 30A and the 35A rating looks very realistic.
The cells do not get too warm at 30A discharge current.
Conclusion
This is a good high current battery.
Notes and links
The batteries was supplied by Vapcell for review.
Время генерации страницы 0.08483 секунды с 15 запросами
