Просмотров в теме 1926   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 17.11.2017, 18:59 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Golisi IMR18650 3000mAh G30 (Gold)
Official specifications:
  • Nominal capacity: 3000mAh
  • Constant current: 25A
  • Nominal voltage: 3.7V
  • Discharge cut-off voltage: 2.75V
  • Charging cut-off voltage: 2.20 +/- 0.05V
  • Internal impedance: 30mOhm
  • Standard charging current: cc/cv <=2A
  • Size: Diameter: 18mm, Height: 65mm
  • Net weight: 46g
  • Cycle times: >800
  • Operating temperature: Charging: 0°C ~ 45°C, discharging: -20°C ~ 60°C
  • Storage temperature: Room temperature or below.
This is a high current 18650 with fairly high capacity.
The battery handles up to 15A nicely, the two cells tracks very fine.
At 15A the cell gets fairly hot
At 20A I had to stop the discharge due to temperature.
And also at 30A.
Conclusion
The cell can handle a good amount of current and has good capacity, but rating the cell for 25A continuous discharge is a optimistic.
I will call it a good high cell.
Notes and links
The batteries was supplied by Golisi for review.
Время генерации страницы 0.11670 секунды с 15 запросами
