Просмотров в теме 1743   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 09.11.2017, 21:27 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Vapcell NCR20700 3200mAh (Gold)
Official specifications:
  • Model: NCR20700
  • Size: 20.0*70.2mm
  • Nominal voltage: 3.6V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50V
  • Typical Capacity: 3200mAh (0.2C discharge)
  • Min capacity: 3100mAh (0.2C discharge)
  • Weight: Max:60g
  • Internal resistance: Max:10mOhm
  • Standard Charge: 2000mA,CCCV 50mA cut-off
  • Charging Time: 3hours(standard charge)
  • Quick Charge Current: 4000mA
  • Max Continuous Discharge Current: 30000mA
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: -20°C~70°C
  • Storage: Temperature -5°C~35°C, Humidity <75%RH
  • Standard environmental condition: Temperature: 23±5°C
  • Humidity: 45-75%RH
A high current cell of the new 20700 size.
The discharge curve is very good, it tracks nearly perfectly and the capacity do not drop much with loads up to 30A
A 30°C temperature raise at 15A, this is easy for the cell.
At 30A it gets fairly hot, but not too hot. 30A looks like a good rating for this cell.
Conclusion
This battery do not have more capacity than 18650, but it handles high current better that the best 18650.
I will call this a very good cell.
Notes and links
The batteries was supplied by Vapcell for review.
m72 (09.11.2017), Андрей Светлов (09.11.2017)
Время генерации страницы 0.08760 секунды с 15 запросами
