Просмотров в теме 1919   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 05.11.2017, 22:22 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Enercig 20700 4000mAh EC-27B (Red)
Official specifications:
  • Typical capacity: 4250mAh
  • Minium capacity: 4000mAh
  • Weight:60g ±3g
  • Diameter: 20.35 mm ±0,1 mm
  • Length: 70.30 mm ±0,25 mm
  • Nominal voltage: 3,6 Volt
  • Charge termination: 4,20 Volt ±0,05 Volt
  • Discharge termination: 2,50 Volt
  • Maximum charge current: 4,0 A (1C)
  • Maximum continious discharge current: 15A (5C)
This is very good discharge curves, they track perfectly. The rated 15A discharge current looks very reasonable.
At 20A the cell gets too hot and I had to stop the discharge.
Conclusion
This size has more capacity and slightly higher voltage than 18650, without being much larger.
The cell is a very good.
Notes and links
The batteries was supplied by ENERDan for review.
m72 (05.11.2017), rpdoctor (05.11.2017)
Время генерации страницы 0.08854 секунды с 15 запросами
