Просмотров в теме 1780   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 03.11.2017, 06:12 Автор темы   1
Последняя активность: 27.05.2019 12:43
Поблагодарили: 10 раз(а) в 2 сообщениях
Отправить сообщение для Angryfox с помощью Skype™
По умолчанию Introducing Angryfox TP10 tactical flashlight
Utilize CREE XML2 U4, XPE2 LEDs with lifespan up to 50,000 hours burn time
Powered by one 18650 battery and two CR123A/16340 batteries
Maximum 1000lumens with beam distance up to 350 meters and 58 hours runtime
Digitally regulated output maintains constant brightness, reverse polarity protection from improper battery installation
Patented unique side light design with maximum 80 lumens
Patented easily disassembled tactical finger ring
Patended two-in-one 360 degrees tactical tail cap switch(Patented)
Made of durable high-grade aluminum with premium Type III hard-anodized anti-abrasive finish
151.5mm Length x 25.4mm Body Diameter x 39mm Tail Diameter, 103g(exclude battery)
Parameters:
Details:
Side light with 80 lumens, it can be as the feet light to light up your feet area, also can be as the reading light:
Multi-colored LEDs are available to enrich your usage
Mic USB charging, the indicator is red under charging, it is green When the power is full
Patented Family-owned “Rattlesnake” clip design
The flashlight can stay at 45 degrees lighting angles all the time When it is hanging somewhere
Two-in-one 360 degree tactical tail cap switch(patented)
Variety accessories: wrist belt, headband, waist clip, colorful filter, diffuse
Enable the flashlight for widespread use
Angryfox вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.07863 секунды с 15 запросами
