Просмотров в теме 1582   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 01.11.2017, 20:57 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Nitecore IMR18490 1100mAh (Black-Yellow)
Official specifications:
  • Capacity: 1100mAh
  • Minimum capacity: 1070mAh
  • Nominal voltage: 3,6V - 3,7V
  • Charge voltage: 4,2V ± 0,05
  • Discharge cut-off: 2,75V
  • Pluspol: ButonTop
  • Max. continuous discharge current: 11A (10C)
  • Chemistry: IMR (LiMg)
  • Protection circuit: None
  • Charge algorithm: CC-CV
  • Diameter: 18,15mm ± 0,05
  • Height: 49,05mm ± 0,12
  • Weight: 32g±1
A fairly high current 18490 (Basically same as 18500) cell from Nitecore.
The two cells have different capacity and do not handle high current the same way. It looks like they can handle 10A
I got a fairly high internal resistance, because I measure it at high load.
Conclusion
The performance is fairly average for 18490/18500 high current cells, but the bad matching means they cannot be used in series.
Notes and links
rpdoctor (01.11.2017)
Время генерации страницы 0.07468 секунды с 15 запросами
