Вернуться   Форум FONAREVKA.RU Источники питания и зарядные устройства Batteries and Chargers. Reviews and tests. Battery chargers. Reviews and tests.
Просмотров в теме 1833   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 27.09.2017, 20:01 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Charger Xtar MC4 update
Review of MC4, read this first
This is a fairly small 4 slot charger from Xtar with usb power input. It can only charge LiIon batteries.
This review will only be an update, not a full review.
Measurements
A normal charge curve, it looks the same as the first review.
With a 0.5ohm resistor in series (i.e. a weak power supply or a long cable) the charger over charged the batteries, the updated version do not over charger, in this case the charge voltage is a bit low (Within the allowed +/- 0.05V).
I tried one test more, this time with a 1ohm resistor, i.e. even worse cable and the charging was perfect.
The orginal test was with 4 cells in the charger and it also looks fine in that case.
Conclusion
This means I will give the charger a good rating.
Notes
The charger was supplied by a Xtar for review.
Here is an explanation on how I did the above charge curves: How do I test a charger
[Исправлено: HKJ, 27.09.2017 в 23:37]
rpdoctor (27.09.2017), vorsmann (28.09.2017)
Время генерации страницы 0.08579 секунды с 15 запросами
