Просмотров в теме 2086   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 22.09.2017, 18:17 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Vapcell INR18650 2000mAh (Black)
Official specifications:
  • Model: vapcell INR18650
  • Size: 18.3*65.0mm
  • Nominal voltage: 3.6V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50v
  • Typical Capacity: 2000mAh (0.2C discharge)
  • Min capacity: 1950mAh (0.2C discharge)
  • Weight: Max:48g
  • Internal resistance: Max:8mOhm
  • Standard Charge: 1000mA,CCCV 100mA cut-off
  • Charging Time: 3 hours (standard charge)
  • Quick Charge Current: 4000mA
  • Max Continuous Discharge Current: 38000mA
  • Operating Temperature: Charging, 0°C ~ 45°C, Discharging, -20°C~75°C, Storage Temperature -5°C~35°C
  • Storage Humidity: <75%RH
  • Appearance: Without scratch, distorion, contamination and leakage
  • Standard environmental condition: Temperature: 23±5°C, Humidity: 45-75%RH, Atmospheric Pressure: 86-106KPA
This is a low capacity 18650 cell that can handle very high current.
Very nice box for the batteries, especially if you want to carry spare batteries. The one I got include a paper with the above specifications.
This is a good looking discharge chart, the cells tracks perfectly and capacity is nearly constant up to (and probably a bit above) 30A
The battery gets warm at 30A, but could handle more current before the temperature would be a problem.
Conclusion
For people that want to play with high current, i.e. 20A, 30A or more this looks like a very interesting cell. But the price is a fairly low capacity.
Notes and links
The batteries was supplied by Vapcell for review.
[Исправлено: HKJ, 22.09.2017 в 18:26]
avglushkov (22.09.2017)
Время генерации страницы 0.09131 секунды с 15 запросами
