Просмотров в теме 9036   Ответов в теме 42   Подписчиков на тему 9   Добавили в закладки 0
Старый 19.09.2017, 12:26 Автор темы   1
Последняя активность: 27.05.2019 12:43
Поблагодарили: 10 раз(а) в 2 сообщениях
Отправить сообщение для Angryfox с помощью Skype™
По умолчанию Angryfox HR06 rechargeable headlamp
1.Utilize CREE XML2 U4 LED with lifespan up to 50,000 hours burn time
2.Powered by one 18650 battery and two CR123A/16340 batteries(can't be charged directly with 2 16340 batteries)
3.Avant-garde design of main light and secondary lights for widely use(Patented)
4.Mechanical rotating bezel design for multi-colored LEDs changing(Patented)
5.Digitally regulated output maintains constant brightness, reverse polarity protection from improper battery installation
6.Maximum 600lumens with beam distance up to 100 meters and 38 hours runtime
7.Secondary multi-colored LEDs are for widely use with maximum runtime over 45 hours
8.Additional warning and strobe light function to meet your outdoor safetly requirement
9.Quiet noise click button switch for power on/off and light level output control
10.Made of durable high-grade aluminum with premium Type III hard-anodized anti-abrasive finish
11.Lightest-weight (108g battery excluded) and compact appearance design(size 76x43x32mm) to make it very easy to carry
Product Parameter
Products detailes:
1. Main lights+3 x secondary lights design(Patented),main light is for throwing long distance beam.
Secondary lights are for short distance with widely use.
2.Compact and smart housing design can be rotated wide range up to 100 degrees with one hand operation
3.Main light: 600lumens maximum, 100 meters beam distance, over 38 hours runtime
4.Rotating bezel design for multi-colored LEDs changing(Patented)
Secondary lights:80 lumens maximum, over 45 hours runtime
5.Secondary multi-colored LEDs design meets outdoor widely use
White light:close distance lighting, general outdoor use and reading
Red light: safty warning, hunting and blood track
Green/Blue light: signal light, atmosphere light, photo back up light and hunting
6.No noise click button switch design
Power on/off; control multi-brightness and different operation functions output;warning mode with double click; Strobe mode with long press
7.Micro-USB waterproof charging plug, the indicator is red when it is charging and green when the battery is full
Please note:it can't be charging directly with two 16340 batteries in it.
8.Optional accessories: Angryfox battery, charging cable
Angryfox HR06 is the newest and unique headlamp in the market, the features are operated by the mechanical structure.
Angryfox вне форума   Ответить с цитированием Вверх
Поблагодарили: 8 раз(а)
AEDe (19.09.2017), fnksb (20.09.2017), Kelevratony (20.09.2017), LEV-UA (20.09.2017), ser-kras (20.09.2017), Tankist_20 (20.09.2017), Алексей Михайлович (19.09.2017), РШ (20.09.2017)
Старый 19.09.2017, 12:42   2
По умолчанию Re: Angryfox HR06 rechargeable headlamp
Price?
Старый 19.09.2017, 13:57   3
Последняя активность: Сегодня 18:36
Сказал(а) спасибо: 2716
Поблагодарили: 12654 раз(а) в 4588 сообщениях
Пару месяцев назад наткнулся на это чудо, правда тогда без зарядки был вроде. Где продается так и не нашел, списался с производителеми они на обзор отправили . Но все еще где-то в пути.
[Исправлено: AEDe, 19.09.2017 в 13:58]
Старый 20.09.2017, 02:11 Автор темы   4
Angryfox
Price?
It is $89.90/Set including the shipping cost.
Старый 20.09.2017, 05:16   5
Where to buy?
Старый 20.09.2017, 05:43   6
Последняя активность: Сегодня 19:56
Сказал(а) спасибо: 17686
Поблагодарили: 39932 раз(а) в 14774 сообщениях
На сайте у них много странного креатива
Про сами фонари, правда, ничего не понятно.
Старый 20.09.2017, 05:59   7
Понятно, что цены у них зебровские
Старый 20.09.2017, 06:09   8
Grammaton Cleric
τετραγράμματον
Аватар для Grammaton Cleric
Сказал(а) спасибо: 179
От западных коллег (в теме презентации сабжа):
- Цена?
- Кто захочет, тот купит!
Старый 20.09.2017, 06:13   9
Сложно судить о ценах на фонарь, который пока толком нигде не продается.
Ну и я, пожалуй, предпочел бы увидеть еще один интересный бренд с ценниками зебры (ну ладно, феникса-олайта-найткора), делающий что-то новое и интересное - чем очередной "скучнокитай за двадцаточку".
РШ (20.09.2017)
Старый 20.09.2017, 06:28   10
Пост с ответом на модерации
fnksb (20.09.2017)
Старый 20.09.2017, 06:41   11
ЗЫ.
И с зарядным шнурком что-то не очень понятно, он отдельный аксессуар вроде как, т.е. ещё +10 или около того
Старый 20.09.2017, 06:45 Автор темы   12
Angryfox
ЗЫ.
The price includes the 18650 3500mah battery, charger cable and shipping
Kelevratony (20.09.2017), ser-kras (20.09.2017)
Старый 20.09.2017, 06:50 Автор темы   13
Angryfox
Вложение 193204Вложение 193205
Вложение 193206Вложение 193207
The function/Features are strong and we don't have words to express that
Sorry to make you confused, we will update our website information to show you clearly about our products, thank you.
Старый 20.09.2017, 06:57   14
It's much better.
Старый 20.09.2017, 08:27   15
MaksVasilev
Аватар для MaksVasilev
Последняя активность: Вчера 17:50
Сказал(а) спасибо: 637
Страшный шопипец, с шайбой вместо морды. Чисто по дизайну никак не лучше боруита выглядит, а по свету скорее всего ничем не отличается от последнего - тирка скорее всего та же.
[Исправлено: MaksVasilev, 20.09.2017 в 08:28]
Старый 20.09.2017, 08:38   16
Сказал(а) спасибо: 6699
вот если б она была задействована как селектор источника света...
Старый 20.09.2017, 08:49   17
galex, так 4 пункт в первом посте.же
galex (20.09.2017)
Старый 20.09.2017, 08:56   18
4 пункт
блин, а я в дальше в тексе искал описание управления. нашел только про бесшумную кнопку.
это ж хорошо. только "механическая" как-то смущает. надо бы магнитное кольцо
Старый 20.09.2017, 09:14   19
galex, ну может имели ввиду что , он физически крутится, кто их знает. Приедет разберу посмотрим. Хотя судя по картинкам на сайте думал он баксов 30-40 )
Старый 20.09.2017, 09:37   20
MaksVasilev
По картинкам на сайте я бы за него больше 8-10 евро не дал бы вообще.
Время генерации страницы 0.12857 секунды с 16 запросами
