Просмотров в теме 1793   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 18.09.2017, 17:42 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Ampsplus INR18650 3500mAh (Black)
Official specifications:
  • Size: 18.35mm x 65.10mm
  • Nominal Voltage: 3.70V
  • Nominal Capacity: 3500mAh
  • Rated Capacity: 3400mAh
  • Charging Metod: CC/CV 4.20V
  • Discharge Voltage: 2.50V (Average Cut Off)
  • Charging Current CC: 750mA
  • Rapid Charging Current: 1500mA
  • Continuous Discharge Current: 10A Max.
  • Short Discharge Current: 20A
  • Battery Rate: 3C
  • Weight: 48gr.max
  • Color: Blue , Black
  • Version: Flat Top
  • Protection: No
This is a high capacity battery with moderate current capabilities.
Discharge curves tracks perfectly.
At 15A the battery gets too hot and I stop the discharge.
Oops, the battery died before my over temperature sensor stopped it. On the second battery I only tested up to 15A
Conclusion
The is a very good high capacity battery, but be careful with current draw above 10A.
Notes and links
The batteries was supplied by ecoluxshopdirect.co.uk for review.
Время генерации страницы 0.08135 секунды с 15 запросами
