Просмотров в теме 1712   Ответов в теме 0   Подписчиков на тему 2   Добавили в закладки 0
Старый 05.08.2017, 10:21 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Efest IMR18650 3100mAh (Purple) 2017
Official specifications:
  • Capacity: 3100mAh
  • Nominal voltage: 3.7V
  • Voltage at end of discharging: 2.5V
  • Max charging current: 4A
  • Standard charge: 2A
  • Discharge current: 10A
  • Pulse discharge current: 20A
  • Charging temperature range: 0° ~ 45°C
  • Discharging temperature range: -20°C ~ 75°C
  • Inner resistance: 20mOhm
  • Cell size: 18.50 (±0.2)mm x 65.20 (±0.2)mm
A 18650 with 3100mAh and fairly high current.
I like the plastic box Efest uses, it is made to protect the battery from impacts.
The discharge curves tracks very fine.
I forgot to put the temperature sensor on one of the batteries.
That means it did run the full discharge curve and got fairly warm
Especially at 20A (It did not work anymore after this test). This also shows that it has proper safety, that disables the battery if it gets way too hot.
Conclusion
This cell has good performance at moderate current, but it is not a super high current cell.
Notes and links
The batteries was supplied by Efest for review.
Время генерации страницы 0.07762 секунды с 15 запросами
