Просмотров в теме 1809   Ответов в теме 0   Подписчиков на тему 2   Добавили в закладки 0
Старый 22.06.2017, 20:16 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of UltraFire BRC26650 7800mAh (Red)
Official specifications:
  • Model: 26650
  • Type: Rechargeable Li-lithium battery
  • Capacity: 7800mAh
  • Voltage: 3.7V
  • Max Continuous Discharge: 8A
  • Max Peak Discharge: 4A      Something is wrong with Peak/Continuous rating
  • Size: about 66*25*25mm
  • Color: Purple
Cheap super high capacity 26650, it is barely necessary to test to give a correct conclusion.
The two cells I tested have different capacity, the best can reach 2300mAh at 0.2A. They can barely deliver 7A.
Even at maximum load the temperature is not that bad.
Conclusion
Different capacity for the two cells, below 1/3 the rated capacity, problems delivering rated current, it is bad cells.
Notes and links
Compare to 26650 and other batteries
Batteries with ridiculous ratings
m72 (22.06.2017)
Время генерации страницы 0.09183 секунды с 15 запросами
