3432
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Shockli IMR26650 5500mAh (Black) 2017
![]() Official specifications:
![]() A high current and high capacity 26650 cell. ![]() ![]() ![]() ![]() ![]() The two cells are very well matched and as usual I test them a bit above specifications. They handled 20A fine, but did not like 30A continuous, it blew a fuse inside both cells, preventing me from doing the rest of the tests. ![]() ![]() AT 20A they get rather hot, I measured about 78°C. ![]() At 30A they reached 86°C before the fuse blew. ![]() ![]() ![]() ![]() Conclusion The performance of these cells looks very good and I will look on it as an advantage that they blew a fuse when overloaded (Instead of blowing up). For vapers that want to use 30A, this fuse is no problem, I draw 30A for about 8 minutes continuous before it blew. Notes and links The battery was supplied by shockli.com for review. How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries Compare to 18650 and other batteries Compare to 26650 and other batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ [Исправлено: HKJ, 19.04.2017 в 21:18] |
Регистрация: 03.09.2019 Последняя активность: 11.11.2019 20:40
Поблагодарили: 19 раз(а) в 17 сообщениях
skorp777 (22.09.2019)
