Просмотров в теме 5746   Ответов в теме 8   Подписчиков на тему 3   Добавили в закладки 0
Старый 24.03.2017, 20:14 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Samsung INR21700-30T 3000mAh (Gray)
Official specifications:
  • Standard discharge capacity: min. 3000mAh (1.5A charge 0.1A cut-off, 0.6A discharge, 2.5V cut-off)
  • Rated discharge capacity: min. 2650mAh (4A charge 0.1A cut-off, 10A discharge, 2.5V cut-off)
  • Nominal voltage: 3.6V
  • Charge voltage: 4.2V
  • Standard charge: 1.5A charge 0.1A cut-off
  • Rated charge: 4A charge 0.1A cut-off
  • Max. continuoys discharge: 35A at 25°C
  • Discharge cut-off voltage: 2.5V
  • Cycle life: 250 cycles to 60% at 35A discharge.
  • Cell weight: 69.0g max
  • Cell dimension: Height: Max: 70.40mm, Diamter: max. 21.22mm
  • Operating temperature (surface): Charge 0°C ~ 50°C (Recommended <45°C), Discharge -20C° ~ 80°C (Recommended <60°C)
  • Storage temperature: 1 month: -20°C ~ 60°C, 3 months: -20°C ~ 45°C, 1 year: -20°C ~ 25°C
This is the new battery size that is slightly larger than 18650 cells. This cell is a high current cell with moderate capacity.
This battery can easily handle 30A and more with constant capacity and perfect tracking between the cells.
I did try a 50A discharge, but my battery holder melted before I was finished with the first trace.
The battery gets warm at 30A, but not too warm.
In this discharge the battery is in free air, i.e. it has better cooling.
Conclusion
This battery is a very good battery and the best high current cell I have tested to date. At lower current there is no reason to use this cell, only when the current is above 10A is this cell interesting.
Notes and links
The batteries was supplied by ENERDan for review.
My test stations is only equipped to handle up to 30A, this means higher current must be done on other equipment.
Compare to 26650 and other batteries
[Исправлено: HKJ, 24.03.2017 в 20:39]
Поблагодарили: 9 раз(а)
fnksb (24.03.2017), Garrik (24.03.2017), Ikepod (24.03.2017), rpdoctor (26.03.2017), vorsmann (26.03.2017), Witchdoctor (25.03.2017), Андрей Светлов (24.03.2017), Сумской (25.03.2017), Ходэн (26.03.2017)
Старый 25.03.2017, 15:17   2
Witchdoctor
Сказал(а) спасибо: 3167
По умолчанию Re: Test/review of Samsung INR21700-30T 3000mAh (Gray)
Any plans on testing Sony US18650VC7?
петцль не фонарь.
Старый 25.03.2017, 15:24 Автор темы   3
HKJ
Аватар для HKJ
I need to find it in a shop first.
Старый 25.03.2017, 23:21   4
IURASHIK
Аватар для IURASHIK
Последняя активность: 11.02.2025 00:33
XXXXXXX
[Исправлено: IURASHIK, 26.03.2017 в 00:58]
IURASHIK вне форума   Ответить с цитированием Вверх
Старый 26.03.2017, 00:20   5
chem
Последняя активность: Сегодня 05:28
Сказал(а) спасибо: 796
Посмотреть сообщение Сообщение от IURASHIK :
но вроде внутренний объём не больше чем в 16850
Вообще-то стандартные банки 18650, соответственно выигрыш по объему существенный.
Старый 26.03.2017, 00:59   6
IURASHIK
Аватар для IURASHIK
Вы правы - попутал малость
Старый 26.03.2017, 07:55   7
Ходэн
Сказал(а) спасибо: 1070
Выглядят хорошо.
Старый 26.03.2017, 13:44   8
IURASHIK
Аватар для IURASHIK
банки или графики?
Старый 26.03.2017, 13:53   9
vorsmann
Ветеринар Фонаревки
Аватар для vorsmann
Сказал(а) спасибо: 10202
:sun_smile: Re: Test/review of Samsung INR21700-30T 3000mAh (Gray)
вот же они и еще тут
In Fino verytas
[Исправлено: vorsmann, 26.03.2017 в 13:55]
Witchdoctor (27.03.2017)
Время генерации страницы 0.10407 секунды с 16 запросами
