Просмотров в теме 3166   Ответов в теме 0   Подписчиков на тему 3   Добавили в закладки 0
Старый 10.03.2017, 16:35 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Soshine 9V LiFePO4 320mAh (White)
Official specifications:
  • Chemie: LiFePO4
  • Size: 9V 6F22
  • Model No.: Fe-9.6V-320
  • Nominal Voltage (V): 9.6 ,charged 10.8V
  • Height (mm): 47.9
  • Diameter(mm): 16, 8x 26,5
  • Weight: 35g
This battery has 3 LiFePO4 cells in series and a protection circuit.
It looks like the protection circuit only works for over discharge where it trips at about 6.4V. On charging I tested up to 12V without triggering any protection, it may be because the protection circuit is for 4.2V LiIon.
The numbers is from the good battery, not an average between the two cells.
Here are the numbers for the bad battery.
Usual a 9V battery has flat sides, but one of these did expand significantly during tests.
The good battery has about 230mAh, not very impressive for a 320mAh rated battery. Voltage is fairly high as expected.
Conclusion
LiFePO4 batteries are low capacity, but with 3 cells in series it has considerable more voltage than most 9V types.
I am not really impressed with the lower than rated capacity and one defective battery.
Notes and links
Compare to other 9V batteries: Alkaline/NiMH/Lithium/other
Время генерации страницы 0.06496 секунды с 15 запросами
