Просмотров в теме 2002   Ответов в теме 0   Подписчиков на тему 2   Добавили в закладки 0
Старый 16.02.2017, 19:11 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Soshine 9V LiIon 650mAh (White)
Official specifications:
  • Type: Rechargeable Li-Po
  • Dimension: (48.5+-0.5)*(26.1+-0.2)*(15.4+-0.3)mm (max)
  • C5mAh: 630(mini)
  • C5mA: 650mAh
  • Nominal Voltage: 7.4V
  • Capacity Nominal: 650mAh
  • Capacity Minimum: 630mAh
  • Service Life: 1000cycles(>=60% C5mAh,0.2C discharge)
  • Weight: 28g
  • Charging Voltage: 8.4+/-0.15V
  • Ambient Temperature Range: Charging: 0-45 centigrade, Discharging: -20 to +60 centigrade, Storage: -20 to +40 centigrade
This is a two cell LiIon rechargeable battery.
It has over voltage protection at 8.63 and 8.64 volt.
It has over discharge protection at 5.08V and 5.57V.
The two batteries are just about the same capacity.
The voltage is lower than NiMH and more like a nearly empty alkaline, but it will stay this way for a very long time.
Conclusion
These batteries have more than double capacity compared to NiMH 9V batteries and are close to a alkaline battery at low load, except this battery will maintain high capacity and voltage at high load.
In moderate to high load situations this looks like a good replacement for alkaline.
Notes and links
Compare to other 9V batteries: Alkaline/NiMH/Lithium/other
Время генерации страницы 0.08498 секунды с 15 запросами
