2205
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
BestFire IMR26650 4500mAh (Purple)
![]() Official specifications:
![]() Extreme high current 26650 cells with good capacity according to the rating. ![]() ![]() ![]() ![]() ![]() Teh two cells are not perfectly matched, but has nearly constant capacity up to 20A. ![]() ![]() The cell has an acceptable temperature at 20A. ![]() I forgot to connect the temperature sensor for one of the cells, but the other cells shows that 30A is about maximum continues current when looking at temperature (The cell hits 80°C). ![]() ![]() ![]() ![]() ![]() ![]() Conclusion The cell is not more than 3500mAh and it can easily deliver 20A, anything above 30A must be done in pulses. The performance matches other high current 3500mAh cells. Notes and links How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries Compare to 18650 and other batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
ko54 (12.11.2016)
Регистрация: 03.03.2015 Последняя активность: 09.04.2020 17:15
Сказал(а) спасибо: 1070
