2287
Регистрация: 14.09.2015 Последняя активность: 22.02.2023 12:30
Записей в дневнике: 2 Сказал(а) спасибо: 1
Поблагодарили: 73 раз(а) в 49 сообщениях
![]() Convoy S2+ LED Flashlight Professional Cree XM-L2 LED flashlight for maximum 960LM output (Both T6-4C and U2-1A) are available. It utilizes 8pcs 7135 driver for multiple mode choice. There are two different modes- 3 modes and 5 modes. When it lasts for more than 3s, a memory mode will on that can memorize the brightness level, or change to next brightness level if it lasts for less than 3s. The light will turn down the brightness automatically and start to blink every 2s when working voltage is 2.9 - 3.1V. A reverse polarity protection feature is to prevent improper battery installation and thermal management to avoid overheating. ![]() Authentic CooYoo Quantum SS Mini LED Flashlight CooYoo Quantum Series may be the smallest flashlights with rechargeable function in the world. Its tiny size, high output and 2 brightness levels make it a perfect all-purpose light. The small quantum can be put into a pocket. You can comfortably carry it all day long at the office or on a camping trip. ![]() Convoy L2 LED Flashlight LD29 driver circuit board ensures constant power. The light will slowly flash to indicate low voltage. There are total 3 modes: High - mid – low. An anti-rolling ring and diamond knurling protect the light from falling. Also, there are memory function and reverse polarity protection features. |
![]() U'King ZQ-X900 Tactical LED Flashlight w/ Focus Zoom The UKing ZQ-X900 is an amazing compact flashlight that is capable of producing a 600Lm maximum output. It is perfect for everyday use and carry and outdoor applications. Featuring a CREE XPE Q5 LED and a precision convex lens, the ZQ-X900 creates a beam with the optimum configuration. A convenient pocket clip allows you to carry your flashlight wherever you go. ![]() Authentic ThruNite TC12 LED Flashlight ThruNite TC12 is more than an EDC LED Flashlight. TC12 is a compact and practical USB rechargeable flashlight that features durability and reliability. TC12 utilizes a CREE XP-L V6 LED and delivers a max output of up to 1000LM that is enough to cover everyday use. It is providing all an advanced EDC or a tactical flashlight can offer. Armed with ThruNite ITC (intelligent temperature control) Technology, and virtually unbreakable aircraft grade aluminum construction, TC12 is absolutely your best choice! ![]() Nitenumen NE01 LED Flashlight CREE XM-L2 LED has a maximum 1000LM output. With Micro USB charging port, you can charge the battery without taking it out. A red and blue battery indicator is user-friendly. There are total 5 modes: Turbo - high - mid - low – moonlight, different modes fit in different use. IPX-8 waterproof standard, gives you a full protection to your Flashlight in your daily life and outdoor activities. Also, a smart constant current drive circuit provides a long run time up to 320h. |
