1985
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
AW IMR18650 3000mAh (Red) 2016
![]() Official specifications:
![]() Batteries with both high capacity and high current ability from AW. ![]() ![]() ![]() ![]() ![]() The discharge curves tracks very nicely and capacity drops only a little with increase current, at least up to the rated 20A. But why do one cell terminate on temperature and other do not? ![]() From this temperature chart the explanation is clear, I forgot to mount the temperature sensor on the A cell. The battery gets rather warm at 15A ![]() ![]() The cell without temperature sensor must have been very warm here. It was warm enough to get damaged! ![]() ![]() ![]() ![]() The damage to the A cell is very obvious here. ![]() And also on this curve. Due to this damage I had to cheat with the "internal resistance" value in the table, it is only for cell B, I did not use the value from the damaged cell. ![]() Conclusion The batteries has good performance but watch out for the temperature at high current. Notes and links The batteries was supplied by aw-akku.de for review. How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries Compare to 18650 and other batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
TimK (12.10.2016)
