Просмотров в теме 2015   Ответов в теме 0   Подписчиков на тему 2   Добавили в закладки 0
Старый 25.09.2016, 18:56 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Shockli IMR26650 5000mAh (Black)
Official specifications:
  • Nominal Voltage: 3.7V
  • Nominal Capacity: 5000mah (1A Discharge)
  • Discharge Cut-off voltage: 2.75 V
  • Standard Charge: 1.0 A /4.2V±0.05V (Recommend 1.0A-2.0A)
  • Maximum charge current: 4A
  • Continuous Discharge Current: 20A
  • MAX Discharge Current: 30A
  • Initial Impedance: <20 mOhm
  • Cycle Life: 500times to 60%
  • Charging Time: Standard charge: 4hours, Rapid charge: 2hours
  • Size(mm): 26.7±0.2mm(Diameter) x 65.2±0.3 mm(Length)
  • Weight(g): 95±2g
  • Operating environment: Charging: 0°C ~ 45°C, Discharging: -20°C~60°C
  • Storage environment: Temp(-20°c -35°c) / Humidity (65±20%)
This is fairly high current 26650 cells.
The discharge curves looks good with good tracking and fairly constant capacity.
I wonder why there is this much temperature difference between the cells, but both handle the 15A discharge without problems.
I suspect that my battery holder was damaged and that was the reason for the higher temperature.
Here both batteries tracks perfectly in temperature (I have replaced the battery holder) and they can handle a 30A discharge, but gets very hot.
Conclusion
This cell has good performance at higher currents and a fairly high capacity.
Notes and links
The battery was supplied by shockli.com for review.
krax (25.09.2016), m72 (25.09.2016)
Время генерации страницы 0.09510 секунды с 15 запросами
