2813
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Charger PSPower NC401
I have not seen chargers from this brand before, but they have a nice line of chargers, this is can charge NiMH in AA/AAA size and 9V size. ![]() I got the charger in a cardboard box with specifications on. ![]() The pack included the charger and a mains cable, the manual was not ready yet. Mains power is directly connected to the charger and it is universal voltage. It do also have a socket for 12V power. The charge status indicators are 3 green leds for each battery. They show charge status will charging and one will flash. There is a small green led for the 9V socket it will flash while charging and be steady lit when finished. If there is an error a led done the 3 strip will flash. The charger has the typically two level slots used for AA and AAA batteries. ![]() And a socket for a 9V cell at the bottom of the charge slots. ![]() ![]() Measurements charger
![]() This is a good -dv/dt charge curve, the trickle charge is at about 50mA. This is a bit high for LSD (low self discharge batteries. ![]() ![]() ![]() The other channels looks the same. ![]() ![]() ![]() And also the high capacity cells. ![]() No problem with the AAA, the charger uses same current as for AA cells. ![]() The charger is a bit slow to detect a full cell, but that is fairly common with -dv/dt termination. ![]() Four batteries are charge with nearly same speed as one battery. ![]() The charger uses about 0.4A from 12V. ![]() M1: 40,4°C, M2: 42,5°C, M3: 42,7°C, M4: 40,8°C, M5: 47,1°C, M6: 37,9°C, HS1: 52,0°C Temperature is acceptable. ![]() The charger needs about 2 seconds to initialize. ![]() Charge current will depend a bit on number of cells in charger. 9V charging
![]() The charge current is below the rated 50mA. The termination looks like a timed termination. ![]() The charge current depends on voltage, it will start chaging a bit above 6V and stop at 10.5V volt. Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems. Conclusion A nice little NiMH charger, it is good at AA/AAA cells and 9V is acceptable. Notes The charger was supplied by Power Advanced Limited for review. Here is an explanation on how I did the above charge curves: How do I test a charger
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
