Просмотров в теме 1825   Ответов в теме 0   Подписчиков на тему 2   Добавили в закладки 0
Старый 17.09.2016, 18:39 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of AW 17500 1100mAh (Black) 2016
Official specifications:
  • Nominal Voltage: 3.7V
  • Nominal capacity: 1100mAh
  • Minimum capacity: 1000mAH
  • Internal Impedance: < 100 m Ohm at 1KHz
  • Ambient Temperature: Standard Charge : 0 C ~ 45 C, Discharge: -20 C ~ 60 C
  • Max. Discharge Rate: 2C
  • Dimensions: 17 X 51mm +/-0.5mm
  • Weight: 30g +/-2 g
One of the more uncommen LiIon sizes from AW.
These discharge curves tracks perfectly and the capacity is constant at any load.
At 3A the cells will warm up, but not that much.
Conclusion
This look like a good cell and this size can be useful. The capacity and current handling is not that great, but when used as replacement for CR123 the performance is more then enough.
Notes and links
Two of these batteries matches 3xCR123 fairly well in both voltage and size and the protection will prevent the batteries being damaged when the run empty.
The batteries was supplied by aw-akku.de for review.
Время генерации страницы 0.09323 секунды с 15 запросами
