Просмотров в теме 1774   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 16.08.2016, 15:34 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Enercig 18650 2600mAh (Gray) 2016
Official specifications:
  • Typical capacity: 2600mAh
  • Minimum capacity: 2500mAh
  • Nominal voltage: 3.6V
  • Standard discharge: CC/CV, 0.2C, 3V
  • End-of-charge voltage: 4.2V +/0.05V
  • End-of-charge current: 0.02C (50mA)
  • End-of-discharge voltage: 2.5V
  • Continuous maximum charge current: 1C, 2500mA
  • Maximum pulse charge current: 1C, 2500mA
  • Continuous maximum discharge current: 20000mA 7.5C or 22000mA 8.5C with temperature cut-off at 80°C)
  • Max discharge current vs. time: 25-30A > 30second, 35A > 15seconds, 50A -> 6seconds
  • Cycle life at 0.5C: 300 cycles to 80%
  • Initial impedance: 35mOhm
  • Weight: 45.5g +/- 0.03g
  • Operating temperature: Charging: 0°C ~ 45°C, discharging -20°C ~ 60°C
  • Storage temperature: -20°C ~ 40°C (Max. 3 months)
A high current cell with decent capacity.
The discharge curves looks very good, the cells tracks nicely and the capacity is nearly constant up to 20A.
The 30A curve is outside specifications, but the cell handles it nicely.
The cells gets warm, but not anywhere near the temperature limit. One of the cells reach 82°C after I have stopped discharge.
Conclusion
This battery is a very good battery with good high current performance, capacity is in the mid range.
Notes and links
The batteries was supplied by ENERDan for review.
Время генерации страницы 0.09865 секунды с 15 запросами
