Просмотров в теме 2061   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 15.07.2016, 18:10 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of K2 Energy 14500 LiFePO4 500mAh (White)
Official specifications:
  • Nominal voltage: 3.2V
  • Nominal capacity: 500mAh
  • Nominal energy: 1.6Wh
  • Chemistry: Lithium Iron Phosphate
This is a LiFePO4 cell, this means lower charge voltage, less energy content and longer cell life.
This type of chemistry has a very flat discharge curve and the two cells match nicely.
The temperature raise is not very high, even at 10A.
At 15A there is no time for temperature raise, before my equipment cuts the discharge due to low voltage.
Conclusion
Depending on equipment the lower voltage may be an advantage or disadvantage, the capacity and energy is lower than normal LiIon. This chemistry is safer, because the self-ignition temperature is much higher.
For some applications this will be a good cell.
Notes and links
Comparison to other LiIon batteries
Время генерации страницы 0.10105 секунды с 15 запросами
