Вернуться   Форум FONAREVKA.RU Торговая площадка Производители/Дистрибьюторы/Дилеры фонарей и аксессуаров SKILHUNT
Просмотров в теме 104160   Ответов в теме 197   Подписчиков на тему 37   Добавили в закладки 1
Старый 27.06.2016, 04:06 Автор темы   1
Аватар для skilhunt
Последняя активность: 10.06.2025 04:25
Поблагодарили: 159 раз(а) в 53 сообщениях
:sun_smile: SKILHUNT H03 H03R led headlamp release, 1200 LED lemens
H03 headlamp
LED: CREE XM-L2 U4
Max output: ANSI 1000 Lumens / 1200 LED Lumens
Max runtime: Few months
Max beam distance: 123 meters
Max peak beam intensity: 3800cd
Waterproof: IPX-8
Impact resistant: 1 Meter
Battery: 1×18650 , 2x CR123A , 2x RCR123A
Rated Range: 2.7V ~ 8.4V
Dimension:
Length 99.9mm / 3.93 inch
Head diameter 23.5mm / 0.93 inch
Body diameter 21.6mm/0.85 inch
Weight: 44g / 1.55oz (without battery)
Accessories: Headband, clip, lanyard, magnet replace rubber pad, Operator’s manual, Warranty card, Spare O-ring
Operation
Battery installation & Replace magnet:Insert the battery into the flashlight,the battery positive pole toward the light head.
Ensure batteries are inserted correctly, the flashlight will not operate with incorrectly inserted batteries. Ensure when the light turning on,the beam is directed away from the eyes.
When take the light with Bankcards(magnetic) or Cell phone,should replaced Magnet with rubber pad.
Flashlight turning on/off:
When the flashlight was OFF status:
Press the side switch to memorized brightness level.
Press and hold the side switch 0.5 second,to low mode.
Quickly double press side switch to turbo mode.
Quickly triple press side switch to strobe mode.
When the flashlight was ON(any mode) status:
Press and hold the side switch 0.5 second to turn off.
Brightness & mode selection:
Brightness level:
Press side switch to Low-Mid-High-Turbo, cycle.
Quickly double press the side switch to Sub-level(i.e between L1 & L2), turn off memorized the last brightness.
Special modes:
Quickly triple press the side switch to Strobe (S1), then double-click to switch S1/S2/S3 mode, Press side switch back to previous brightness level.
Low voltage indication
When the battery voltage drop down lower than 3.3V, indicator flash twice every 2 seconds. Battery voltage drop down to lower than 3V, indicator flash 3 times every second.
Location indicator & Lock-out function:
When turn off the flashlight, press switch 1.5 seconds, location indicator switch on and lock-out function activation at the same time, Press button onl can switch the indicator on/off.
The indicator light flash every second, locate the flashlight, easy find the flashlight in the dark quickly. Hold press the switch 1.5 seconds, switch button unlock and enter into low mode.
Features
Super bright & latestCREE XML-2 U4 LED, Max 1200 LED lumens. High-Performance, High-Efficiency and energy conservation.
Bead surface lens ,wide and uniform flood beamshot.
Flat tail cap with strong magnet to secure to ferrous surfaces.
Rugged indestructible aluminum body with anti-scratching type III hard anodization
Multi-level dissipating heat design and thermoelectric separation
copper star-board, excellent heat dissipation. Flashlight head integrated construction, high thermal conductivity.
Side switch button to transferring mode user-friendly interface to adjust output.
Eightoutput levels and three Strobe, suitable for different environment.
Wide input range provides more choices of batteries. High efficiency driver circuit, no visible flash in any mode.
Automatic memory function, remember last used setting and can be preset to specific output mode for instant access.
Reverse polarity protection, to protect from improper battery installation.
Low-voltage prompts function, the light will flash when the battery is low,remind user replace the battery on time.
Engineered anti-slip knurling for a tightly firm grip.
Dual recoil absorbingsprings, better impact resistance.
Tail stand as a candle-light.
New intelligent temperature control technology for headlamp stable and safe use
Low standby current below 0.5uA
New side switch lock-out function.
http://www.skilhunt.com/pro...
[Исправлено: skilhunt, 27.06.2016 в 04:11]
skilhunt вне форума   Ответить с цитированием Вверх
99amper (04.07.2016), fnksb (27.06.2016), Loki13 (27.06.2016), Rocklight (27.06.2016), Алексей Михайлович (27.06.2016)
Старый 27.06.2016, 07:53   2
Rocklight
Аватар для Rocklight
Сказал(а) спасибо: 1116
По умолчанию Re: SKILHUNT H03 H03R led headlamp release, 1200 LED lemens
Интересно, в таблице с рантаймами есть прочерки на Т1 и L2, к чему бы это?
Старый 27.06.2016, 07:58   3
Loki13
ё
Аватар для Loki13
Последняя активность: 15.12.2025 13:06
Сказал(а) спасибо: 139
Поблагодарили: 121 раз(а) в 71 сообщениях
Отправить сообщение для Loki13 с помощью ICQ Отправить сообщение для Loki13 с помощью Skype™
Знакомые рёбрышки.
Выключение по длинному клику всё ещё живо.
Loki13 вне форума   Ответить с цитированием Вверх
Старый 27.06.2016, 08:20   4
baldhead
Последняя активность: Вчера 11:07
Сказал(а) спасибо: 47
Поблагодарили: 37 раз(а) в 25 сообщениях
И красный маячок отключить навсегда невозможно?
baldhead вне форума   Ответить с цитированием Вверх
Старый 27.06.2016, 08:23   5
Последняя активность: Вчера 11:49
Сказал(а) спасибо: 6701
Посмотреть сообщение Сообщение от baldhead :
можно просто не включать
вероятно:
т1 - работает термостепдаун, время замерить затруднительно
л2 - некогда так долго проверять, продавать надо уже.
Старый 27.06.2016, 08:44   6
Алексей Михайлович
Последняя активность: Вчера 09:44
Сказал(а) спасибо: 1413
Алексей Михайлович вне форума   Ответить с цитированием Вверх
Старый 27.06.2016, 12:05   7
OTBEPTKA
Последняя активность: 19.09.2024 14:36
Сказал(а) спасибо: 161
Поблагодарили: 21 раз(а) в 15 сообщениях
Для сравнения с H02 и RX60 cвёл основные параметры в табличку.
OTBEPTKA вне форума   Ответить с цитированием Вверх
Loki13 (27.06.2016), narmattaru (28.06.2016)
Старый 27.06.2016, 12:52   8
Loki13
ё
Аватар для Loki13
2xRCR123A = 2x16340?
Старый 27.06.2016, 12:57   9
Посмотреть сообщение Сообщение от Loki13 :
нет, через запятую
да
[Исправлено: galex, 27.06.2016 в 13:00] Причина: букву R не разглядел
Loki13 (27.06.2016)
Старый 28.06.2016, 17:44   10
obivatel
Сказал(а) спасибо: 319
А такая версия действительно будет?
Предзаказ на ГБ: http://www.gearbest.com/led...
obivatel вне форума   Ответить с цитированием Вверх
Старый 03.07.2016, 22:03   11
nab
Последняя активность: 20.02.2024 00:04
Сказал(а) спасибо: 185
Поблагодарили: 77 раз(а) в 49 сообщениях
Самый главный вопрос: будет ли механическая защита от переплюсовки и если да, то можно ли ее будет выпилить также легко как на h15?
nab вне форума   Ответить с цитированием Вверх
Старый 04.07.2016, 02:09   12
obivatel
Посмотреть сообщение Сообщение от nab :
Если не секрет, для чего выпиливать?
Старый 04.07.2016, 03:26   13
Grammaton Cleric
τετραγράμματον
Аватар для Grammaton Cleric
Последняя активность: Вчера 10:06
Сказал(а) спасибо: 179
Посмотреть сообщение Сообщение от obivatel :
Некоторые принципиально любят плоский плюс юзать и беззащитку.
Старый 04.07.2016, 05:46   14
99amper
Последняя активность: 06.05.2018 10:34
Сказал(а) спасибо: 1078
Поблагодарили: 39 раз(а) в 30 сообщениях
Подпишусь.
99amper вне форума   Ответить с цитированием Вверх
Старый 04.07.2016, 09:07   15
Waryag
Аватар для Waryag
Сказал(а) спасибо: 3647
Скорее имеют немалый парк таких аккумов и не хотят получить проблемы с совместимостью.
Старый 04.07.2016, 10:04   16
nab
Именно!
Старый 04.07.2016, 10:23   17
Burlaew
Последняя активность: 02.12.2020 22:19
Сказал(а) спасибо: 519
Поблагодарили: 142 раз(а) в 91 сообщениях
а напаять пипку сложно?
Burlaew вне форума   Ответить с цитированием Вверх
Старый 04.07.2016, 12:22   18
obivatel
А.. ну так то я тоже один из них Я так давно не видел 18650 с не плоскими плюсами (и защитой), что забыл что бывают и такие.
В 2х Скилхантах H02 у трудятся "плоскоголовые" без проблем, не вижу причин, что бы они (проблемы) возникли в H03.
Посмотреть сообщение Сообщение от Burlaew :
Наверное можно испортить аккум перегревом, в теме про переделку шуруповертов на литий, акумы спаивают между собой быстрым точным движением с использованием подходящего флюса.
Старый 04.07.2016, 12:35   19
Burlaew
Ничего не портится, много раз припаивал. За 2 секунды аккум не успевает нагреться
Старый 05.07.2016, 10:20   20
Tatamovich
Аватар для Tatamovich
Последняя активность: 19.12.2018 17:55
Сказал(а) спасибо: 475
Поблагодарили: 156 раз(а) в 84 сообщениях
У Н02 пружинка в голове. Или нет?
Tatamovich вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.14978 секунды с 16 запросами
