Просмотров в теме 1852   Ответов в теме 0   Подписчиков на тему 2   Добавили в закладки 0
Старый 07.06.2016, 14:46 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of AW 18500 1500mAh (Black) 2016
Official specifications:
  • Nominal capacity: 1500mAh
  • Nominal Voltage: 3.7V
  • Diameter: 18.45mm
  • Length: 51.33mm +/- 0.05mm
  • Max. discharge rate: 2C (3A)
  • PCB protection against overcharge, over discharge and short circuit
  • Safety vent with thermal cut off protection
This cell from AW is a bit shorter than 18650 cells and is used in a few devices (2 of these cells matches 3 CR123 in length and voltage).
The discharge curves looks good, the two cells match nicely and capacity is nearly constant independent on load, but the cells are not for high current.
Even when discharging at 5A, the cells do not get unresonable hot.
Conclusion
I have a suspicion that just about all 18500 cells on the market uses a old design and that is the reason for the fairly low capacity.
With that said these cells look good up to a few amps.
Notes and links
The batteries was supplied by aw-akku.de for review.
Ходэн (07.06.2016)
Время генерации страницы 0.09226 секунды с 15 запросами
