Просмотров в теме 18308   Ответов в теме 54   Подписчиков на тему 8   Добавили в закладки 0
Старый 07.06.2016, 12:21 Автор темы   1
Последняя активность: 03.12.2025 20:24
Сказал(а) спасибо: 102
Поблагодарили: 110 раз(а) в 39 сообщениях
По умолчанию MecArmy FM11 SS 10180 Мини-налобник со встроенной зарядкой и универсальным креплением
Новинка MecArmy FM11 появилась в продаже у hkequipment цена с купоном MAHL $56.02
Найдено на просторах интернета:
MecArmy FM11 User Manual Primary Features
· Patented USB rechargeable Multifunctional Flashlight
· Durable stainless steel body
· CREE XP-G2 S4 LED, max output 130 lumens
· Rechargeable 10180 li-ion battery (included)
· Standard Micro USB charging port, charges in just 1 hour from any USB source
· Charging and fully charged indicator
· 3 mode design, Med/ Low/ High
· Easy to access to different lighting functions
· Specially designed switch gives easy one-handed operation, and prevents accidental activation
· Magnetic tailcap provides versatile hands free operation
· Headband allows use as headlamp
· Detachable clip
· IPX-8 waterproof
Specification Emitter: CREE XP-G2 S4 LED Output & Runtime Mode/ Speci cation High Output (Lumens) 130 Runtime 30min 3.4h 15h
Charging When battery is low, unscrewing the light head and connecting the Micro USB cable to charge as shown in the diagram below Charging Indicator When charging, the light turns red, when charging is complete, the light turns green. No light indicates that there is no load Charging time: 1 hour
WARNING:
· Do not point the light at human or animal eyes
· Do not look directly into the light when it is switched on
· Do not permit children to use the flashlight unsupervised Maintenance
· Remove battery when stored for extended periods
· Replace and lubricate O-Rings as needed to maintain IPX-8 rating
· Every 6 months, thread should be wiped with a clean cloth followed by a thin coating of silicon-based lubricant Warranty Service
· Guaranteed exchange up to 15 days after purchase: any defective product be exchanged for a replacement through a local distributor/dealer within 15 days
· After 15 days: all defective products can be repaired free of charge for a period of 5 years from the date of purchase
· Lifetime workmanship guarantee: after the free maintenance period has expi -red, the maintenance service will charge for material expenses only, free of labor expenses. ALTUN LIMITED Peak beam intensity Max beam distance Impact resistance Waterproof
· Dimensions Length: 56.5mm/2.22in Head dimension: 16.9mm/0.67in Body dimension: 13.2mm/0.52in 910cd 59m 1.5m IPX8 (underwater 2 meters)
· Weight: 32.9g/ 1.16oz (excluding battery)
· Battery: 10180 100mAh Li-ion battery
· Working voltage: 3.2V-4.2V
· Accessories: Manual, lanyard, clip, 2xO-rings and headband
NOTICE: The above-mentioned parameters are approximate and may vary between flashlights, batteries and environments.
Sipik SK68 | TrustFire mini-01 | UltraFire UF-H6 | Nitecore D11.2, TINI2 SS | Spark SG5 NW | XENO Tiger E03 v3 XP-G R5 NW |
CQG Bullet XP-G2 R5 NW | DQG AAA SS Tail Clicky NW | CooYoo Quantum SS | Skilhunt H15 H02 NW H03 NW, H04 NW, H150 NW | Manker U11 NW, E02II, III NW, E03H II, III NW | Olight H1 Nona NW | Rofis TR10, TR15 | Lumintop E05C | Wurkkos HD15
[Исправлено: gtr, 07.06.2016 в 12:30]
gtr вне форума   Ответить с цитированием Вверх
Старый 07.06.2016, 12:32   2
По умолчанию Re: MecArmy FM11 SS 10180 Мини-налобник со встроенной зарядкой и универсальным крепле
Посмотреть сообщение Сообщение от gtr :
Так-то уже [IMG]http://cs-mapping.com****/forum/images/smilies/boyan.gif[/IMG]
Но, ладно, повторюсь.
PinkFloyd (09.06.2016)
Старый 07.06.2016, 12:37 Автор темы   3
gtr
Так-то уже
можно пояснить, что не так?
[Исправлено: gtr, 07.06.2016 в 12:38]
Старый 07.06.2016, 12:39   4
Можно пояснить, что не так?
В смысле?
В приведённой вами простыне характеристик всё нормально для налобника?
[Исправлено: Qwertus, 07.06.2016 в 12:40]
Старый 07.06.2016, 12:44 Автор темы   5
gtr
В смысле?
Вроде да, смотря для каких целей.
Неясны только люмены среднего и минимального режима.
[Исправлено: gtr, 07.06.2016 в 12:46]
Старый 07.06.2016, 12:48   6
Для любых
Ну и если уж продолжать, то
$56.02
= $56
Старый 07.06.2016, 12:55 Автор темы   7
gtr
= $56
H02 дешевле.
Старый 07.06.2016, 13:09   8
Grammaton Cleric
τετραγράμματον
Аватар для Grammaton Cleric
Сказал(а) спасибо: 179
Пойдёт ака наключник (в ящик иногда светить, напр.). Не более.
Ну а в остальном - тупизмЪ шедевральный!
[Исправлено: Grammaton Cleric, 07.06.2016 в 13:12]
Старый 07.06.2016, 13:15 Автор темы   9
gtr
Пойдёт ака наключник (в ящик светить, напр.).
Не более.
Макс режиме 130 Лм - 30 мин
Средний ?? Лм - 3,5 часа
В авто запаску поставить, жидкости подлить, не?
[Исправлено: gtr, 07.06.2016 в 13:18]
Старый 07.06.2016, 13:20   10
H02 дешевле.
Дешевле не значит лучше.
Макс режиме 130Lm - 30 мин
Для светодиода CREE XP-G2 бина S4 световой поток при токе 280 mA составит 136 lm
В 15 минут поверю. И то не на все деньги.
Rocklight (13.10.2016)
Старый 07.06.2016, 13:30   11
Grammaton Cleric
τετραγράμματον
не?
EDC? За 56? 100mAh?
Не. Эта "музыка" спецом для ценителей садо...
ЗЫ
Раньше скончается владелец или гнездо зарядное?
Старый 07.06.2016, 13:40   12
surf839
Аватар для surf839
Последняя активность: Сегодня 10:23
Сказал(а) спасибо: 2112
а чё? десять минут света за 56 бакинских, норм)))
surf839 вне форума   Ответить с цитированием Вверх
Старый 07.06.2016, 13:55 Автор темы   13
gtr
В общем зря старались китайцы...
Старый 07.06.2016, 21:53   14
Waryag
Аватар для Waryag
Сказал(а) спасибо: 3647
А чем он будет лучше зебр на АА в качестве налобника?
Чем он будет лучше ААА/10180 наключников в их нише?
Возможностью совместить, пожертвовав рантаймом, весом, светом и эргономикой?
Старый 07.06.2016, 23:28   15
Al
Аватар для Al
Сказал(а) спасибо: 1730
56 в длину, ну как наключник с кнопкой вполне покатит
Старый 08.06.2016, 00:09   16
DoubleDragon
Аватар для DoubleDragon
Последняя активность: Вчера 01:44
Сказал(а) спасибо: 799
Да фиг знает, может кому и приготится. Не офонаренным нефонравщикам на подарок. Выглядит (на мой взгляд симпотно).
С режимами они конечно дали жару. Там бы 2 люмена и 20 сделать. И хватит. Ну и цена раза в 3 меньше.
фонари Zebralight
Старый 08.06.2016, 01:52   17
Smirnov
Сказал(а) спасибо: 308
Хотели сделать самозаряжающимся и чтобы исключить случайную установку на зарядку с одноразовой батарейкой внутри, выбрали, хрен знает какой формат. Но ничего, пользователь вынет батарейку из брелка сигнализации, установит в этот фонарь, поставит его на зарядку и таки спалит свою хату.
Smirnov вне форума   Ответить с цитированием Вверх
Старый 08.06.2016, 08:44 Автор темы   18
gtr
На мой взгляд:
Размер, вес, встроенная зарядка, нержавейка.
Универсальное крепление.
Остаются неизвестны люмены на 3,5 ч и 15 ч.
Старый 08.06.2016, 09:50   19
Waryag
Аватар для Waryag
На мой взгляд:
Вес мимо, тушка весит как 52 зебра и больше, чем 502. Нержавка для налобника - скорее минус, именно из-за веса. Встроенная зарядка нужна из-за отсутствия рантайма.
Вы внимательно рассмотрели фотографию фонаря в креплении? Затемнение, наклоненная голова - всё, чтобы скрыть убогость крепления на клипсе к резинке, которое не зафиксирует фонарик.
Старый 08.06.2016, 10:06 Автор темы   20
gtr
Понятно, что крепление клипсы к резинке будет болтаться, и оно хуже чем штатные крепления налобников из силикона.
Время генерации страницы 0.13370 секунды с 16 запросами
