2445
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Soshine 18650 LiFePO4 1800mAh (Black)
![]() Official specifications:
![]() Soshine has a series of LiFePO4 cells, this is their 18650 sized one. ![]() ![]() ![]() ![]() ![]() ![]() This is a typical LiFePO4 discharge curve and it looks good. As can be seen the voltage is nearly flat during discharge and then drops very fast when the battery is empty. ![]() ![]() ![]() ![]() ![]() LiFePO4 has a significant voltage drop when charging stops. Conclusion The cells looks like good LiFePO4 cells, but I wonder about the fairly low current overload protection. There is also the usual limited capacity with this chemistry, it has less than half the energy of a modern 4.2 volt LiIon cell. Notes and links How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries Compare to 18650 and other batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
