Просмотров в теме 1808   Ответов в теме 0   Подписчиков на тему 2   Добавили в закладки 0
Старый 13.03.2016, 20:51 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of GB 8.4V (7.2V) 6800mAh battery pack
Official specifications:
  • Type: Battery
  • Battery Type: Lithium-ion
  • Battery : 18650
  • Rechargeable: Yes
  • Voltage(V): 8.4V
  • Capacity: 6800mAh
  • Charge Time: 5 - 6h
  • Discharge Time: 2h
  • Over Voltage Protection: Yes
  • Over-charging Protection: Yes
  • Over-discharging Protection: Yes
  • Short Circuit Protection: Yes
  • Product weight: 0.196 kg
  • Product size (L x W x H): 8 x 8 x 5 cm / 3.14 x 3.14 x 1.97 inches
Inside the rubber is some shrink wrap around the cells.
The protection circuit looks like it checks all cells, but it do not have balancing.
There is no strain relief on the cable.
Connection cable is slightly above 0.5meter.
The protection circuit, one chip and two dual transistors.
Capacity varies with load and due to cable/connector resistance (Both pack and my test cable) the over discharge protection kicks in at different voltage (At the battery it will be 6 volt all the time).
I wonder why the 5A trace has as little capacity as it does. The Panasonic NCR18650B cell can handle 5A.
Conclusion
I like the rubber packing and the supplied pouch, this makes it fairly easy to mount on a bicycle and gives some protection for bumps.
The pack can deliver the rated current, but not more than that. The missing strain relief is rather bad.
Notes and links
The battery was supplied by Gearbest for review.
combat_rabbit (13.03.2016), WallE (13.03.2016), Андрей Светлов (13.03.2016)
Время генерации страницы 0.07961 секунды с 15 запросами
