Просмотров в теме 1834   Ответов в теме 0   Подписчиков на тему 2   Добавили в закладки 0
Старый 26.02.2016, 19:46 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Imren IMR18650 3000mAh (Yellow)
Official specifications:
  • Weight: 50g
  • Capacity: 3000mAh
  • Length : 65.05mm
  • Diameter: 18.51mm
  • Voltage: 3.7V
  • Excellent high-current discharge performance
  • Model: 18650
  • Material: Li-Mn
Imren has two different 3000mAh cells, both high current.
The discharge curves looks good, nearly constant capacity and very good tracking between the cells.
I had to stop early on the high current discharges to avoid melting my test station.
At 30A the temperature increases very fast, I terminated the discharge after 2 minutes and 30 seconds.
Conclusion
The cells looks good, but they cannot deliver 30A continious.
Notes and links
The battery was supplied by Imren for a review.
This test is run on my updated equipment and is not directly comparable to the other Imren 3000mAh test.
barena (26.02.2016)
Время генерации страницы 0.07960 секунды с 15 запросами
