1738
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Efest IMR18650 2500mAh (Purple) 2016
![]() Official specifications:
![]() A 2500mAh battery with a fairly high current rating. ![]() ![]() ![]() ![]() ![]() ![]() The discharge curves look very good, they tracks perfectly and capacity is nearly constant. The battery got warm at the higher current and I had to stop. ![]() ![]() I stopped this discharge a bit early due to temperature. ![]() For now I am running with a fairly low maximum temperature (This trace here melted one battery holder). Remember the traces are temperature increase, i.e. the actual battery temperature is 25-30°C higher. ![]() ![]() ![]() ![]() Only B battery is valid, the holder for A is melted. ![]() Only B battery is valid, the holder for A is melted. ![]() Conclusion The battery has good performance, but gets warm at 30A (Not a big surprise). Notes and links How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries Compare to 18650 and other batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
| Поблагодарили: 2 раз(а) |
m72 (22.02.2016), Андрей Светлов (22.02.2016)
